  • Replies 93
Ummm, mine.
Lags a bit at the top end so need to upgrade the coil packs
Hicas comes on and feels weird so I need a lock out bar
The pwer wondows rattle a lil bit and may need to have the windows re tinted
The nuff nuff paid to put the 400R body kit on did a messy job on the wheel arches, need fibre vision to look at fixing them up. See them tomorrow.
Oh yeah, and had to settle on my 2nd choice for personal plates becaue BLINKY was already taken... (see previous thread for more info)
Other than that I am happy.
Blinky
problems with the three two
~4 stud
~clutch is crap
~gearbox is crap
~brake master cylinder cracked a seal and is now leaking
~ripped bushes in stock castor rods
~water getting inside the boot
~you cant wind the passenger side window up with the passenger side button but driver has complete control of it
~shift knob is crap
~aircon climate control is being crap
~and last but not least ITS NON TURBO AAAAAAHHHHHHHHHHHHH!!!!!!!
Hmmm....
- Missfire under boost (Coilpacks need replacing)
- Side tinting needs re-doing as there are these two annoying visible lines
- Wheels haven't arrived yet
- Paint/body needs freshening up
- Eclipse satnav/cd player is shizen
- Brakes occassionally squeaky
- Front bar ever so slightly not fitting right due to my gay driveway
- Right headlight is yellow
Thats about it. I was happy a little while ago...
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
