  • 6 months later...
  • Replies 93
Got rear ended = broken rear bumper (again! :cool: ) & now the exhaust also has multiple leaks & most of the support clip things all got knocked off & middle section of the pipe is just dangling around & scraping on every bump I come across.
Still waiting in queue to get it fixed, gonna be waiting for ages due to panel shops being flooded with hail damaged cars...
Belts all makes an annoy whining sound when cold & power steering is making annoy whining sound too when I do a full lock turn at low speed.
Holes in exhaust
Couple of dents here and there
Choke pull off not working (sluggish in mornings/cold)
Rust under boot rubber, front drivers side wheel arch and under battery.
Clutch pedal clicks 80% of time.
Loud Diff whine
Need new tyres.
thats all i can think of so far
first thing in morning on random occasions clutch/gearbox whines when i push the clutch in :down: stops after a minute or so...
4th gear grinds every now and then (random occurrence to)
evc-s restarts if i leave my ipod/iphone plugged into deck :)
Squeaky clutch :laugh:
Couple of small paint chips that were rusted when I bought it, hasn't spread & I've been too lazy to get them fixed up
First->Second gear crunches a bit below 2700rpm changes
Car isn't idling smoothly... revs are constant but it loses consistency every 5-10 seconds for a quick moment then returns to normal. I assume that's a sparkplug issue or something (not very mechanically minded)
2 years after buying it I still haven't bothered putting in an adapter or new head unit that would allow me to pick up Australian radio stations :thumbsup:
One of my nismo rim caps still needs painting before being put on
What's wrong with mine? Hmmm...
After spending obscene amounts of money over 6 years on it, I sold it for 1/5th of the price only to have the new owner crash/write it off 3 months later. *Sad in pants*
you're yet to see what it's become :P
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
