  • Replies 93
Ummm, mine.
Lags a bit at the top end so need to upgrade the coil packs
Hicas comes on and feels weird so I need a lock out bar
The pwer wondows rattle a lil bit and may need to have the windows re tinted
The nuff nuff paid to put the 400R body kit on did a messy job on the wheel arches, need fibre vision to look at fixing them up. See them tomorrow.
Oh yeah, and had to settle on my 2nd choice for personal plates becaue BLINKY was already taken... (see previous thread for more info)
Other than that I am happy.
Blinky
problems with the three two
~4 stud
~clutch is crap
~gearbox is crap
~brake master cylinder cracked a seal and is now leaking
~ripped bushes in stock castor rods
~water getting inside the boot
~you cant wind the passenger side window up with the passenger side button but driver has complete control of it
~shift knob is crap
~aircon climate control is being crap
~and last but not least ITS NON TURBO AAAAAAHHHHHHHHHHHHH!!!!!!!
Hmmm....
- Missfire under boost (Coilpacks need replacing)
- Side tinting needs re-doing as there are these two annoying visible lines
- Wheels haven't arrived yet
- Paint/body needs freshening up
- Eclipse satnav/cd player is shizen
- Brakes occassionally squeaky
- Front bar ever so slightly not fitting right due to my gay driveway
- Right headlight is yellow
Thats about it. I was happy a little while ago...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
