Hi Guys,
I am in the process of putting together my first Rb30det, and have spent hours reading the threads. I would like to here some of your thoughts on the setup I am planing to run.
Currently I have a
- r32 Rb25DE Head, which has been cleaned up, new valve stem seals, and equivalent GTR valve springs.
- 2x RB30 Blocks
- ACL rebuild kit (cast pistons over-sized, rings, bearings ect)
- All new gaskets
- Rb26 Oil pump
- Crank collar
Support mods include
- Rb25 GCG High-flow 14psi actuator (min psi it can run)
- Sard 650cc injectors
- Splitfires
- FMIC, 3" turbo back (no cat)
- z32
- Sard FPR
Drive train
- RB25 Box with 5 puck button Exceedy.
Tuned Via Nisstune ECU.
I am doing this on a budget, and can do alot of the work myself, I have all the support mods from my current RB20 set up (hence the RB25DE head). But I have heard the NA heads have bad flow and can be restrictive.
This engine will be used for hill climbs and drift, mostly drift, so I want a reliable motor.
Concerns:
- My power goal would be around the 250rwkw (please let me no if you think this is un-achievable), and would love 700nm + torque.
- Could my goals be achieved on a standard Rb30 bottom end? Or should I rebuild it with my cast pistons and new bearings?
- Also for my goal and intended use, is standard pistons ok? Or should I really consider forged?
- The small RB25 high flow turbo could also see as a restriction, choking up the exhaust side. Or power-band could be peaky to early, maybe unusable? Thoughts?
If you have any other thoughts or suggestions on my planed build please let me no your thoughts.
https://www.sau.com.au/forums/topic/285340-first-rb30det-advice/
  • Replies 41
stockies will do. but i wouldnt rely on your ecu.. any detonation and bang. you budget just doubled. since new turbos are all around the same price id go a nice gt3076. .82a/r
Yeh stock rebuilt? Like ACL, or just freshen up the old stock bottom end?
I will be going with a reputable tuner, and I no nisstune can be a limitation, but it does retain stock knock sensors. But yeh the stock internals doesn't leave much room for internals.
I would be planing to keep Revs below 7000 (along side all relivent oil control mods)
New turbo is really pushing the budget, but is something I am considering in future.
Do you have the GCG already?
If so, thats ok.
If not - 3076 or 3071 as stated (.82)
Hey mate, currently running this turbo on my RB20.
Also trying to get my hands on an OP6 rear housing, which would be a cheaper option having it rebuilt then a whole new turbo.
it will have a chunky power band from 1500 - 5500 more than that and there is so much exhaust gas that the turbo cant get rid of it and backpressure starts killing off all the power.
This was one of my original concearns in my first post. Is there anything bar changing the turbo to help relieve this? A freerer flowing exhaust manifold (or porting out the stock manifold), heat wrap on the manifold and dump? , larger dump?
I wouldnt waste time building the motor with ACL cast pistons and rings. Stock rings are stronger, so id just use a stock bottom end (un-touched). you would be surprised how much power they will handle
I started with RB20 hiflow on mine and made 240rwkw, so you should do 250rwkw with the rb25 housings.
Thanks mate, yeh I always have a spare bottem end to build up if somthing goes in this one.
Would it be worth just freshening it up? The bores are abit glazed, and new rings wouldnt hurt.
Also if I need to fit a crank collar the whole thing needs to come apart anyways. Thoughts?
If you're pulling it all down then make sure the crank is straight and has no end float, I didn't do that the first time and ended up having to pull the engine out, put new bearings and oil pump in. Cost like $100 to get the crank ground for oversize bearings.
IMO when you have the block sat there you may as well hone it and fit new rings. minimum. i wouldn't want to use a worn 200,000k+ RB30 for my build. But +1 on using the stock rods and pistons rather than aftermarket casties.
You would be better off doing what bubba said too and fitting new bearings across the board while your at it.
Thanks GT-RZ and Bubba thats most helpfull, I think I will freshen up the the stock bottem end, with new rings, bearings and hone.
Also looking at my turbo options.
Considering a 3076r .82 A/R, when does this turbo make full boost, and what kind of power would I make with this turbo. I would like it to be responsive, and maintain and beefy and linear power curve.
Refer to this thread:
http://www.skylinesaustralia.com/forums/30...on-t285067.html
page 2 or 3 i asked almost the identical question you did. I'm leaning towards the gt35 twin scroll (1.06 rear housing) but have not dropped the idea of the 3076 with the 1.06 housing, not considering the .86 anymore though.
haha thats crazy, I just read that thread to only come back here for you to suggest reading it.
I think now for me is whether to go a Gt3076 but in .82 or 1.06. Very interesting read tho, I was actually going to refer to it here to see others thoughts.
I am also considering internalgate just for simplicity, cost, and stock look low mounted.
I've gone for a GT3582R with a 0.82 exh housing, stock 25DE cams for now - will let you know how it goes in a month or two.. I'll be happy if it makes 1bar about 3000rpm and 500rwhp! :)
Edited by bubba
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
