  • Replies 41
i run the 3076r 0.82 (external gate version) on a freshened stock internal 26/30 (so lowish comp around 8:1 from memory), its making 18psi at roughly 2900rpm
Sweet! I think that bodes well for my 1bar by 3000rpm expectation for the GT35R :D
Thanks GT-RZ and Bubba thats most helpfull, I think I will freshen up the the stock bottem end, with new rings, bearings and hone.
Also looking at my turbo options.
Considering a 3076r .82 A/R, when does this turbo make full boost, and what kind of power would I make with this turbo. I would like it to be responsive, and maintain and beefy and linear power curve.
that would be my choice of turbo, decent power and torque without much boost the nistune should have no dramas tuning up perfect providing its done right. The r32 ecu's are actually quite good.
bubba, i will be able to tell you what mine gets in a couple of weeks (GT35R 0.82 rear, 25/30 with 9.4:1 comp, ETM manifold, external gate) should be fairly comparable with your setup.
Nice! Pretty similar to mine except I've got 6boost manifold with 50mm progate and my compression is only like 7.5:1 due to my engine being originally built before people made 30DET pistons.. guess that just means I can wind a shitload of boost and timing into it :thumbsup:
That's another reason why I'm not putting huge cams in, with the low compression and huge cams it'd probably be a complete pig off boost!
I'm holding off sending my bits to be balanced as I'm waiting for some splined oil pump gears :D
Edited by bubba
Trent do you have any idea of where the power tappers off with this turbo. I am not going for highest KW figure, just somthing usable, but if there isnt much to play with after 5000rpm then would consider mayb a gt35 or a 1.06 A/r for the gt30.
Still in two worlds about what to do.
So many people say dont bother touching the 200K + bottom end, just bolt the head on and go for it! "you will be suprised how much they will handle" Just keep revs below 6500.
others
Atleast new bearings rings and hone.
Also undecided, I can afford either a new turbo gt3076r, or prep the bottom end properly. As my power goal is more of a beefy/reliable 250-270rwkw will using my GCG highflow be of any danger to the motor? Will the power just be too peaky and unusable?
Build the bottom end properly, then save for a real turbo.
I drove my 30 with a 25 turbo on there for over a year, drove like a diesel but still fun, just couldn't rev it past 6000rpm (power nosed over at 5800rpm and by the time it got to the 6800rpm limiter it was only making 90hp!).
Loaded up on a dyno on 4th?
Or on the street in 2nd/3rd where you spend most of the time :P
others
well if you don't mind putting in a stock bottom end and having a guess if it will last then it's up too you? personally i wouldn't want to rip my motor out just because i now realize it's blowing like crap and the 20yo rings needed replacing...
bearings, rings, hone then at least you have an old component motor running like new. plus doing that wont cost too much.
I see it this way... a new motor with me replacing it costs around $500...
I'm gunna put an old one in and wind the boost right up into it...
i see it as waste of time. I'd rather do things right the first time. i'd be an unhappy man if i built a motor then to rip it out a month later because i never gave it new rings.
might be lucky, might not be. i don't have the time to take the gamble and rip my car to pieces because i was lazy the first time round.
on the street actually on a 3rd or 4th gear from low rpm run, havent been on a dyno yet to see, its been street tuned. This setup in a r32 or 33 would be awesome, in the stagea i have it in it is just abit heavy, though it goes alright and still only have a crap 2.5' muffler on it which i think is killing the top end.
If you're building it to last, sure...
But whilst you're there you should do the oil pump, all the mods, custom sump, forged pistons etc...
I wouldn't trust 20 year old pistons to last, even with fresh rings and hone...
My "stock" bottom end RB30, will be exactly that... STOCK...
I'll let you all know how many minutes it lasts... :)
i found a large lip in the bores of mine so bored it to 86.5mm and threw in some Endurotech cast pistons which are supposed to be abit stronger than stockies and allow for a good piston to bore clearance rather than honing worn bores. The pistons were only $320 with rings so about $200 for the actual pistons (as rings are around $120 anyway) which is bugger all and mine are running 18psi no dramas at moment and i will building another engine the same as this for my track car and throw my hks t04z on it and see how long it will last for abit of cheap fun :)
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
