haha nah guys thats not my stagea...put it up as the avatar cos its mint! :P
Picked up the stag tonight...abit dark for photos tho so I will take some tomorrow.
There was a burning oil smell when i looked at the m35 first and got a full inspection done...apparently the
oil dip stick was half way out and put oil all over the right hand side of the engine bay.
Can still smell oil now even though the workshop did a clean of the engine.
Im thinking theres still some excess oil left there or maybe a gasket is stuffed?
anyone had similar problems?
Also the Airbag sensor light is flashing...they checked it out and fixed it but it started flashing again
after a couple of hours.
Heres some more pictures of the first rims...I like them the most too....nice a classy but tough at the sametime.
  • Replies 93
Posted Images
Hi JDMWGN.
I have also had the problems you have just described.
They seem to have a bad connection somewhere in the airbag circuit which triggers the error, mine is still flashing.
I also had the same burning oil smell and tracked it down to the seal around the rear plug on the passenger side. It will be full to the brim with oil and overflowing onto the turbine housing, not very safe. If you get the dealer to import a new cover it will take ages, I just used a sealant on the rubber seal as they arent replaceable. Replace the plugs while youre there.
What colour is yours? I will keep an eye out for it. :)
The burning oil smell is worse when driving....specially when flooring it but if its sitting there idling it goes away.
strange!
There's a thread somewhere that talks about this issue, and refers to the G35/Z33 which is prone to the problem. Do a youtube search and you'll find a vid of someone discovering the issue. I think a new cam-cover is required to fix the problem properly, but a dose of sealant may do the trick.
rear plug, passenger side.
I disagree, a new cover will probably leak too. Just seal it, unless you can find some aftermarket alloy covers?
When is the meet? :)
Yeah, I was going to ask as well....
Welcome to the club Michael, but I do think I am getting heavily out numbered by you low slung guys.. Any other tall boy AR-Xs in Vic?
Just means we will need to arrange a cruise with a whole heap of speed bumps, or somewhere where my rear LSD helps...
Jumping on the kerosene budge in a a few hours so should be back home 24 hours later in time to take the old girl out for a drive... Better say hi to the family as well....
lol......yeh Cam!!!!!
what's with selling your PM bumper BTW?
cheers mate, the interior looks alot better in person.
camera flash makes it look shitty.
I havent looked at the rear passenger spark plug yet but i found that video on youtube on a G35 i think it was.
shitload of oil in that plug aye.
what spark plugs do you guys use for the VQ25DET.
should setup a cruise soon for the VIC boys!
Im going to go with these wheels....the ones above were $2800 posted from japan...to much for what it is.
Koya kahn 20" below
Are you doing the plugs yourself? You will need a syringe with a tube on the end to suck the oil out.
The oil only weeps in over time so you dont have to worry about doing the seal straight away.
cheers for the help scotty, how hard is it sealing the seal? is it under the rocker cover or is the VQ25DET different to the SR20DET :)
Yeah I think its a Tweeter andy...its not working though but I have a set of new pillars coming from japan already because they look ugly lol
I noticed my stagea didnt come with any gauges in the headunit area....must of been pulled out maybe?
If youre doing the seal yourself, it will take a while. The manifold has to come off and the loom over the engine moved out of the way. Nowhere near as simple as the sr motors.
Dont try and remove the seal, it is glued in and if damaged a new valve cover will set you back $300. Also, go easy on the sealant as you dont want excess floating around your engine.
I was lucky with my gauges, they were in the boot due to a double din TV install and I had to ask for them to be refitted.
How much do you want for the muffler, is it 3 inch stainless? Mine is too loud. :D
The HKS DeModa (which is what this one looks like) is a 2.5" (65mm) cat-back.
well if u wanna sell the muffler
ill buy it off ya
BTw i dont think rx250's came with gauges
Didn't notice it was an RX (didn't look at the rear pic :D ).
That has to be the 1st RX I have seen without the stacker and integrated head unit.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
