  • Replies 93
Posted Images
haha, I will try and get some taken tonight...give it a clean first.
My engine light come on the other day after I installed new headlights. (removed airbox and coolant bottle to get my hand in)
Had a look last night and one of the hoses from the intake pipe to the standard boost controller (only controls spikes) did come out, probably came out
when i was moving the afm around.
what would cause this?
cheers
only if you switch on the ignition or start the car with anything unplugged, and as cam said, it will be away about about 10 successful starts. i went to the dealer twice to get it cleared, but one time i couldnt be bothered but then it went away so i just leave it for a few days now............
So how much do you want for the rear muffler?
Given how huge the centre muffler is, not sure how much of a restriction it is, but it would be absorbing a tonne of energy/sound. Would imagine that the bulk of restriction would be in the 4 cats before you get to the centre muffler...
WTF..... 4 cats?
I only HAD 2. now 1 less.
If my memory serves me correctly, you've only got 2 cats Nick.
Dump & front pipe (as it should be from factory). Mine was the oddball exhaust, so don't go by that (dump, 3 or 4 in front pipe)
Edited by iamhe77
Plus the two in the exhaust manifolds (headers)... one on each side...
Need to have one in the manifold to be a LEV (Low Emissions Vehicle). These ones are supposed to remove all the nasties before the engine warms up properly..
che?
The VQ25det powered M35's were never a low emissions vehicle.
The PM35 was with the VQ35de and the VQ25dd, but never the turbo.
Pretty sure my exhaust manifold doesn't contain a couple of cats... but I feel the need to have another look now
RAWS Consumer Information Notice for my car states that 3 new cats were fitted at compliance :)
Two have the same part number and I assumed are in the manifolds area and the other third one, I also assume, would have been between the dump and the jumbo mid muffler..
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 馃槢
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
