A simple solution with WI/WMI is to have a level switch in series with the boost solenoid . If the level is too low, then it disconnects the boost solenoid and your back to std boost. This assumes your running abit higher than spring pressure.
If you don't use a controller, or its only a tad above base spring pressure, then you need to wire an input to the computer to pull timing as Trent suggests.
If you don't have a spare input or use a stock comp, then wire the level switch to a bright in-your-face light on the dash so you can't miss it !!
Gary
Edited by Fastrotor
Gary
or a seat mounted tazer.
To tell u the truth running out of water/meth is the least of my concern as i check fluids in my car every other morn. and my trips are short.
My main concern is either the checkvalve getting clogged or seizing or if using a solenoid, it fails.
Having said that which do u prefer... solenoid or checkvalve?
Damn Sadist Trent. :D Ouch
Yes but it is always preferable to have things automated. What happens if the fluid leaks out overnight on the 'other' day you don't check it ?
And as for the other stuff failing, well... how far do you go monitoring things. Everything is possible but just not practical.
A check valve is simpler. Just make sure it will handle the methanol.
Gary
My fluid level switch will be hooked up to an input on the ecu, when it triggers it will change to secondary fuel/ignition maps that have been tuned without WMI that way if the tank starts to run low the ecu changes maps early (there will also be a switch on the dash to manually switch to the non WMI maps)
Your probably better off fitting it yourself, setting the basic tune, and then getting a pro to dyno it in - save a heap of $$$$
And if you look at ebay USA, you can see the relative prices of each kit. This will help you as a guide as well. I wouldn't think fitting would be a cheap thing to pay for.
If you're serious about a methanol injection system then you speak with the best, Joe Signorelli.
its hardly rocket science :happy: but they are top operators.
details below;
Rotor Master Racing Innovation
Address: Unit 9
38-44 Elizabeth St,
Wetherill Park NSW 2164
Ph: 001 61 2 9604 4801
Fax: 001 61 2 9756 2362
E-Mail: [email protected]
Edited by URAS
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
