Hey guy i'm wondering what the difference between a split dump and bellmouth one is. Which style would be better aswell?
I've tried searching but keep getting an error 3312 and this is over the course of an hour.
Thanks for you time
Sunny
https://www.sau.com.au/forums/topic/285414-dump-pipes/
But seriously, each to their own. Some people will tell you there is no difference, some will say it makes a massive difference, 99% of them probably haven't gone from one to the other on the exact same car so aren't really fit to comment.
Personally, I don't think there is a difference as with an internal gate you are fairly restricted in the power you can make anyway so flow at that point is not really a concern. Get whatever is cheapest and/or the most shiney.
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793115
Theoretically split dumps should work better, but that hasnt been confirmed in the real world and there doesnt even seem to be anecdotal evidence to support it either. Also you need to take more care with split dumps to verify everything fits well, in particular that the wastegate flapper doesnt catch.
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793154
I agree...
I recently bought a cheap split dump and the wastegate flapper was catching like a bitch. Plus it's travel has been severely affected too, giving me other problems. I think with the more expensive split dumps you shouldn't have any trouble, it's just the cheaper ones that have poor weld jobs and pipe allignment. Gonna try a JJR system next and hopefully that bolts up no hassles.
I think all the split dump will do is alter the sound of the exhaust a bit...
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793386
bell mouth is superior. simple.
split dumps on small internal gate turbos are a big compromise as you end up with 2 very small pipes. and they then merge almost straight away anyway.
also the claim of improved spool up is bullshit. how can they possibly improve spool up? while the turbo is spooling up the wastegate is CLOSED so the split is doing nothing. split or not split there is no wastegate gass mixing with turbine gass until the gate is open by which point the turbo is at or very near target boost. the bell mouth (well a good one) gives you greater overall area, gives greater flow, will make more power, and response (allows the gas to expand quickly) and you have no risk of any of the stupid problems people get with the cheap split dumps with wastegate flaps fouling etc.
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793641
Agreed :P
Although i would have said go with the one that is best made (which doesn't necessarily mean the most expensive)...
Having to change out a dump because it was a cheap ebay special and the welds have split is definitely not cool :P
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793678
Dont mean to hijack the thread but what would the HKS dumps for GTR be? Will it be logical to change the stock one for them (not changing turbos at the same time)?
The reason for asking is if there' no real/significant gain, I wouldnt be putting them on (only after around 300awkw and no more).
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793704
Big call to say the theory is bullshit if you havent studied fluid dynamics....(my guess is you havent :-)
Consider the flow path from the turbine - its actually better in a split dump, especially when the wastegate is closed, so theoretically will present higher pressure difference across the turbine, and therefore it will spool better. The fact that the bellmouth is "big" is not beneficial, it causes more turbulence, which is more restrictive than a less turbulent path. When the wastegage opens the difference is less pronounced. Of course everything i'm saying is a massive oversimplification as well. Back to back dyno (or CFD) is the only way to KNOW.
https://www.sau.com.au/forums/topic/285414-dump-pipes/#findComment-4793902
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
