r34 NA Neo engine comes with
tiptronic gearbox
alternator and all ancilliary brackets
loom and ecu
manifolds and front pipes, $1500
R32 Rear subframe $200
Cefiro Rear subframe $200
Damper adjustable S13 shocks with lowered springs (front only) $200
s14 5speed gearbox (2 of) $600 each
Aftermarket S14 front pipe (2of) $80 each
S14 manual gearbox xmembers (3of) $70 each
R33 manual gearstick surround $40
R33 VLSD's 4of $300 each
R32 GT-r front pipes (2of) stainless steel 3in $150 each
Evo 8 Lancer stock suspension (full set) $500
Mazda3 strut brace still in box $150
Mazda3 Grill as new $150
Mazda 3 LHS Headlight $200
Civic Type R Jap spec LHS headlight $200
Random skidders with tyres mostly 17s, varying widths $50 each
R32 factory side skirts 4 sets, two white, two black. $100 a set
MAKE AN OFFER ON ANY OF IT!
Plenty more where that came from, try me i might just have it
Located at Dinmore, but can meet closer to Brisbane if needed
0400 039899 or pm
cheers
Jason
https://www.sau.com.au/forums/topic/285425-garage-clean-out/
pics of the black r32 sideskirts?
sorry mate, been busy with an overheating car today, i'll get on to that first thing in the morning for you.
cheers
Jason
second pair can be had for $50, as one is damaged damaged.
Hi mate,
keen on this item. 'R33 manual gearstick surround $40' what is condition like, do you have pics? also would you come down to $30? can pick up
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
