Hey all,
Last night I got home at about 7pm and parked my car in my carpark underground in the basement of my appartment building in southport. This morning I have gone down to get in it to take it to have my new bumper, side skirts, and rear pods fitted and noticed it was gone. took me 10 minutes to come to my sensus and admit to myself that it is actually gone.
The car is a Maroon R33 GTS model. Very distinctive skyline not like others, it has a black bonnet, black roof blending into the sides. GTR wing, LR style front bumper and a front mount intercooler on the front. The rego plates on it are SKY008 and it has a silver square fuel sticker cover. It also has black and silver rims very distinctive. It also has a red jetpilot sticker on the rear windscreen.
I will post pictures up of what it looks like at the moment.
EVERYONE BE ON THE LOOKOUT PLEASE AS IT IS VERY DISTINCTIVE.
Please contact me on 0402859795 for info or PM me instantly please.
Thanks,
Ben H
Update:
THE REWARD FOR THE RECOVERY OF MY CAR IS GOING TO SIT AT $1000.
*The car has apparently been spotted in brisbane near the springwood exit but for all we know it could be on the coast now or somewhere in Brisbane. Any information on the car would be very much appreciated.
Hey all,
Last thursday night I got home at about 7pm and parked my car in my carpark underground in the basement of my appartment building in southport. The following morning I had gone down to get in it to take it to have my new bumper, side skirts, and rear pods fitted and noticed it was gone. took me 10 minutes to come to my sensus and admit to myself that it is actually gone.
Thanks,
Ben H
Footage of car being taken:
https://www.sau.com.au/forums/topic/285428-skyline-stolen-urgent/
  • Replies 185
Yeah I bought it at the start of last year for 8k and have spent around 4k on it but its only insured for 8 which sucks. So yeah everyone please keep an eye out. was able to get the passenger window deflector off the ground that they must have ripped off. hopefuly get prints off it.
Much gheyness, I hate hearing these stories. Is it a "secure" underground carpark? The Gold Coast definitely seems to be getting hit pretty hard at the moment.
A GTS with 4 stud wheels and a FMIC, did it have a turbo conversion? It might help with identifying parts if that's the case.
In any case I'll keep an eye out around the Brissy northside!
If only they had known then they could have postponed :P
on a more serious note - will keep an eye out
bad lack mate
Hey mate, where in southport were you? Pm me if you dotn want to say up here. I live in southport too. Was it in a secured carpark or just an underground carpark? Its gotten so bad lately. A S14 got pinched the night before from Railway st apparently. Nice looking car too.
Did i see a photo of you in the paper getting ride height tested in the crack down the otehr week? Did they do you for anythingt hen?
you should of spent that first 4 grand on a alarm system man. hope u find it in one piece
+1
*EDIT*
I take back my plus one, and would rather say:
You should HAVE spent that first 4 grand on AN alarm system man. Hope you find it in one piece.
I can't second bad spelling/grammar, sorry. But I do hope you find your car.
Edited by Isola
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
