  • Replies 185
maybe today will be the day! fingers crossed. indicators dont work either unless the crooks go them fixed so look out for a maroon skline with black bonnet, black roof, gtr wing and non working indicators lol
he knew it was just joking - heading out to jambo today
(like an hour drive) so will keep an eye out
yeeh i knoww, just wanted to seem like the sensitive one :)
lol
fineline yes noel i have heard how deadly your trawler is ;)
man that shit aint even a joke - ive watched deadliest catch - those big ass mo-fo trawlers hall ass! :down:
lol ill just get in my skyline and go look for it, nah man I dont have another car. My sister is driving down from mackay to pick me up to go look.
thanks all for everything keep an eye out please!
Yeah I would have been there in the past few months but if you see it now it is not me driving it, it is some crook who does not give a shit about anyone else.
The car was last seen near the springwood exit heading nortbound, I have no idea where abouts it would be but im guessing somewhere in the brissy area, theres still a chance it could be on the coast but seing as though it was spotted heading northbound it may be in brissy.
I will sort out a reward being good cash $$$ at least for the person who can assist in the recovery of the vehicle.
fineline yes noel i have heard how deadly your trawler is :)
sad to say but i wanna sit shotgun when u take it out for a spin :$
ill even let you school me in RB26's *blush*
He doesn't know shit about RB26's and has no want to either.....
i seen ur number plate within the past few weeks sometime(i live in a time warp so i have no recollection of date), in maroochydore pretty sure parked in maccas, i took a pic on my phone but deleted it cos it didnt turn out. ...have you been up this way recently
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
