  • Replies 185
They loved me in Mackay, got pulled over 17 times in one week, crazy huh, wasnt even doing anything wrong, here on the gold coast though i havent been pulled over yet, probably wont ever now lol
17 times in a week ...lol.... @ least they cant say they dont no what the car looks like if it shows up there , mind you drivin a sick lookin 33 like that why wouldnt they ....jelous.....
lol a very dirty one at the moment. they had to bloody rip my passenger window rainshield off didnt they, took me 6 months to get one of those and by the looks of things they didnt even open that window because when the car leaves the window was up... questions questions
I think theres gona be a segment on it on channel 9 news tonight so ill be watching, I may be on it, they came by here this morning for details
well when ya think bout it everyone in here has 1 thing in common " there car " and im pretty sure that if you put the time , effort and wrench work into somtihng and then some povo fu@k thinks that he can just flog it and get away with it ...... then they just gotta deal with what is dealt out.
Hey just saw this thread, that totally sucks man. I'll definately keep a eye out for it. I'm on the road going from coomera to the gateway every weekday (2hrs of driving!!) so if I spot it I'll stalk it for you and will break any road rule to stay with em! :D
Hopefuly the guy is still using it to drive around and hasn't started selling parts of it!
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
