Hey all,
Had a bit of bad luck, the motor has lunched itself a bit. The bolt holding on the idler snapper (10mm smegging bolt) and the timing belt let go and has bent the valves etc... So I would like to sell it all in one go, I just dont have the energy for it anymore - Im not going to part it out, so dont bother asking.
Has rego, and a whole lot of good stuff with it, looks pretty stock and was pretty quick and fun to drive. Below is a bit of a list of some of the bits and pieces that will come with it:
December rego
New Federal tires
New stuff: walbro fuel pump, oxygen sensor, front drive shafts, coil packs,
Other stuff: rb25 and rb20 turbo, r34 intercooler plumbed into stock location, split dump, 4" hks exhaust, hicas lock bar, coilovers
Stock interior in great condition, carpets and dash are like new - no bubbles.
Few other bits and pieces. I have spent a lot of hours cleaning it up and sorting things out with it, so it should be a good little project for someone
I would like about $4500, but very negotiable, I really need to sort out some transport for myself. Cheers all
Dave
https://www.sau.com.au/forums/topic/285449-fs-r32-skyline-gts4-blown-motor/
Swaps? I am keen on getting a liberty wagon, must be manual tho :P
Oh, and I can put on some other rims, still r32 rims with less tread on the tires to drop the price a bit more if anyone was interested
Edited by Medium Dave
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
