once again the boost controller arived in perfect condition...
thanks once again...
Adrian
ALSO can you pm me some pics of the front bar, my mate might be keen... also does it fit with the front reo ???
  • Replies 114
HKS Cams 264 9mm lift (must remove vct) 800$ post-10915-1251429698_thumb.jpg post-10915-1251429742_thumb.jpg
HKS in tank fuel pump 320$ post-10915-1251430281_thumb.jpg post-10915-1251430307_thumb.jpg
Defi Link Meter Boost + Defi Control unit 2 300$ post-10915-1251430670_thumb.jpg
R33 GTR adjustable rear strut brace 120$ (must have for gts-t owners) post-10915-1251430983_thumb.jpgpost-10915-1251431042_thumb.jpg
Tein super street damper aus spec 1200$(almost new less than 2000km)post-10915-1251431773_thumb.jpgpost-10915-1251431755_thumb.jpg post-10915-1251431738_thumb.jpg
Greddy Plenum + Greddy TB adaptor 1000$ (powder coated blue + clear) post-10915-1251431972_thumb.jpg
Greddy Aluminum Radiator R33 (free nismo cap) 450$ post-10915-1251432074_thumb.jpg
Sard fuel pressure reg (+ braided lines+fittings + silicon hose) 150$ post-10915-1251432339_thumb.jpg post-10915-1251432375_thumb.jpg
HKS SQV BOV (plumb back adaptor+ pipe if wanted) 220$ post-10915-1251432473_thumb.jpg
Whiteline heavy duty sway bars 300$ (will clean blue paint off before purchase) post-10915-1251432576_thumb.jpg
HKS type s intercooler 300$ (slightly bashed at bottom no leaks) post-10915-1251432709_thumb.jpg
Carbon Fibre door sills 80$ post-10915-1251432799_thumb.jpgpost-10915-1251432857_thumb.jpg
33GTR door trims 200$ front rear post-10915-1251432949_thumb.jpgpost-10915-1251432997_thumb.jpgpost-21107-1124968569.jpg
rb26 rocker covers + hks badge 500$ (powder coated blue+clear +braided lines + nismo cap)post-10915-1251433200_thumb.jpg
White face Cluster 100$ (stock cluster with white face over top lights up 3 colours) post-10915-1251433308_thumb.jpg
series 2 dash + shift surround (proffesionally painted 2pak silver looks factory) 200$ post-10915-1251436575_thumb.jpg
HKS Silent hi power cat back 600$ (comes with free HKS removable silencer) post-10915-1251433698_thumb.jpg post-10915-1251433732_thumb.jpgpost-10915-1251433754_thumb.jpg
Genuine R33 GTR grill + GTS BADGE (1 of 2 made... dudes offer me there wife for this badge) grill needs small plastic weld..150$post-10915-1251433913_thumb.jpg
DO LUCK flat trunk genuine 500$ post-10915-1251434021_thumb.jpgpost-10915-1251434151_thumb.jpg
East bear dry carbon bonnet very light 400$ ( suits someone who wants to paint ) post-10915-1251434267_thumb.jpgpost-10915-1251434287_thumb.jpg
HKS 555cc injectors ( no pic as i left them in fuel rail to save damage free rail for buyer) 750$
all parts in sydney..no lowballing..please pm if SERIOUSLY interested..or if you can email me as i can only answer pms once a hour at the moment..
do you still have the bonnet?
Rear bar and side skirts also for sale now..
both veilside combat by fibremotive....best copy kit i have seen in au qual wise...thicker and stronger than my jap made veilside e1 kit..
rear bar 280$
side skirts 200$
pics attached
not keeping HKS GTR-S turbo kit...its for sale now...checked over by turbo guy...no shaft play at all..10,000kms
2100$ comes with everything needed to bolt up to rb20-25..posting in here first so previous customers get a heads up before i list in its own thread..
pm if interested
