well i have an rb20det..
but i got a r32 mines tuned ecu but the connection for the mines is bigger than the stock one :S
its really weird because pretty much everythin i buy for it that is off an r32 doesnt fit coz the plugs r different.
As long as you have an RB20DE or DET any R32 ECU should fit.
Incorrect :D
The RB20 in some A31's are different to R32 mate and the ECU in the series 1 isn't interchangeable either is the ignitor, CAS etc as the plugs are different. You can either change the wiring harness/ignitor to run the 32 ecu or you will have to get another A31 ecu :)
Sounds like you have the eariler Redtop HR31 ecu \ loom in there, I would personally change everything required over the the silvertop R32 loom \ ecu and go from there :cool:
but its the stock engine and its the silver top rb20det..
would it just b easier to buy an rb25 with all the wiring and put that in?
A31's wiring harness is different to the R32 wiring harness for silvertop mate depending on what year it is so not necessarily running a red top loom.
Well it depends what you want to do with the car and what exactly is your problem in the first place to warrant a different ecu cobber???
nope you need a cefiro ecu or you need to swap in a R32 engine harness to use r32 ecu (or pinswap a header plug).
wat u mean pinswap a header plug?
i new cefiro parts were hard to find but i didnt know they werent even the same as the r32 :)
typo replace a with on. :)
cefiro has no consult wiring etc.
Edited by URAS
I was of the impression the ECU's were still swappable even if the loom had the square shape connectors.
The ecu plugs are different sizes so not interchangeable unless you have a R32 wiring harness installed to run the 32 ecu.
