How long have you owned your V35 for? Just over 1 year
Where did you buy it from? (import, private, dealer): Private import, compliance by Tokyo Imports
What type of V35? (Coupe/Sedan,Manual/Auto): Coupe Auto
How much did you pay for it? About 25k all up
How many problems/faults have you had with it (please give detail): Speaker problem (Sound jumps from left to right speakers)
How much has it costed repairing these problems?: NIL, lol havent done it yet
How much do you get out of a full tank of petrol?: About 450-500Max, not daily drive so heavy on the right foot.
And lastly, 0-100, how fast do you reckon? Dont care. +FAST ENOUGH, when last car was mums 07 C200 Kompressor!
How long have you owned your V35 for? 6 MONTHS
Where did you buy it from? (import, private, dealer): PRIVATE (he'd only just imported it through my friends car yard a few months prior)
What type of V35? (Coupe/Sedan,Manual/Auto): AUTO
How much did you pay for it? 28K
How many problems/faults have you had with it (please give detail): NONE *touch wood*
How much do you get out of a full tank of petrol?: EST. 600km
And lastly, 0-100, how fast do you reckon? Who knows, fast enough to keep me happy ...for now :D
How long have you owned your V35 for? Just over a year
Where did you buy it from? (import, private, dealer): Private import, compliance by Kamikaze
What type of V35? (Coupe/Sedan,Manual/Auto): 2003 70th Anniversary Coupe Auto
How many problems/faults have you had with it (please give detail): None
How much has it costed repairing these problems?: N/A
How much do you get out of a full tank of petrol?: Between 550 and 600kms
And lastly, 0-100, how fast do you reckon? A lot faster than my last car (Pulsar)
How long have you owned your V35 for? 2 and a half years
Where did you buy it from? (import, private, dealer):[b] Dealer: luxury performance imports melbourne[/b]
What type of V35? (Coupe/Sedan,Manual/Auto): 03 Auto Premium Coupe
How much did you pay for it? $38k back in 07How many problems/faults have you had with it (please give detail): Passenger window replaced, rear endlink stabilizers, 3rd brake light, starter motor done under warranty, clicking axle fixed
How much has it costed repairing these problems?: passenger window = $250.00, Rear endlink $50, 3rd brake light= $100, starter motor $300.00 but covered under warranty. There was nothing wrong with it started first go however on cold start it started to make this noise.
How much do you get out of a full tank of petrol?: around 400km on city driving
And lastly, 0-100, how fast do you reckon? Havent tested
Edited by T88turbo
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
