stripping complete r33 series 1 5 speed gtst
have all panels and lights
complete interior etc etc
some parts just off the top of my head
EXTERIOR
front gaurds
bonnet
boot with wing
m spec side skirts
doors complete with glass
rear bar
front lights
rear lights
all windows
rear wiper
front wipers
INTERIOR
rear seats
dash
dash cluster
dash facia
door cards
a/b piller plastics
back plastics
hood lining
rear view mirror
glove box
centre console
all pedals
UNDERCAR
front and rear hubs/knuckles/conrol arms/calipers/struts damper adjust (kyb i think)
3inch cat back exhaust
steering rack
engine cross member
located northern nsw/gold coast
pm me if interested in anything
thanks
https://www.sau.com.au/forums/topic/285505-wrecking-complete-33-gtst/
  • Replies 91
hey mate,
im buying a new 33 gts in the next little while, what the condition of the parts? can you PM me pics. just of the interior dash.
Cheers
not sure if ur asking if its aturbo model or if i have the turbo but yes yes
turbo had just been rebuilt when car was pulled off the road
has zero shaft play :) pretty much new
thanks
1side skirt white
1sidesjirt burgundy lol
will find out make of exhaust
$400 for just turbo
it was just rebuilt before being removed from car
has zero shaft play pretty much as new
i have stock series 1 and series 2 steering wheels
both are abit worn but
will check the lights to see condition but
dont have the rest sorry
thanks
Hi there, i will take the: RB25DET Crossmember, RB25DET Rubber Engine Mounts, RB25DET Alumunium Engine Mounts. Please let me know ASAP. Thanks. My Email: [email protected]
PM me a price on this stuff please:
rear calipers with brake lines to first conection,
rear backing plates,
and hand brake cable set up from both sides up to where it meets the conection and goes to one cable
also rotors if in good condition same with pads,
thanks, mike
thanks
Can you post/pm me a picture of the series 1 steering wheel? Is it the non-airbag one?
Also do you have the stock Boss kit thing?
Thanks.
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
