Hey
I Have,
1 x Set of Ferodo DS2500 Brake pads ( Part number # FRP3077H )
Dimensions are 152mm x 54mm x 17mm
These Pads suit all G4 Racing 8 piston calipers, D2 and Ksport. They also suit the AP Racing 6 Piston Units.
They are brand new! only been trial fitted to calipers, Come boxed in the Original Ferodo Box.
These pads cost around the $370AUD mark depending where your buying them from. Some Australian Suppliers will try and sell them for $400 and up!
Feel free to PM me to make a reasonable offer or reply to this post, Or you could put a bid on these on eBay, bidding has started at $260AUD! I will post these anywhere in Australia.
Grab yourself a bargain! excellent pad for someone wanting a balance between road and track.
More info on these pads can be found at
Thanks for looking :)
Cheers.
Edited by rbr31andrew
Have Relisted the pads on ebay! Feel free to make me an offer. Need these gone!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...%3D1&_rdc=1
Asking price is $250 , Thats a saving of over $100
There must be someone with a set of G4 racing 8piston, Ksport 8 piston or AP Racing calipers that need a set of Ferodo DS2500 for Track days/Road who want to save over $100 dollars on the retail price ? ?
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
