FOR SALE:
i have two die - cast models for sale.
-AUTO ART Motor Sports Calsonic GT Nisan Skyline R34 GTR
-1/18
-$250
-ToyZone HKS Nissan Skyline R32 GTR (LIMITED EDITION)
-1/18 Scale Die - Cast-Only 400 made this is number 387, product of KYOSHO
-$500
Please PM me your interest.
https://www.sau.com.au/forums/topic/285541-118-die-cast-models-r32-r34-gtr/
