Hi everyone.
Time to let the rotary go guys. im starting my electrician apprenticeship next year and will need to buy something more usable e.g.vy ute
also open to trades cash my way
down to details:
POWER: 232RWKW 16PSI (240rwkw 17PSI)
TUNER: DALTON AUTOMOTIVES (CHRIS)
PRICE: $14,000 ono
MAKE: MAZDA
MODEL: FC RX7
YEAR: 89'
REGO: DECEMBER 09'
RWC: NEGOTIABLE
contact: PM or 0431324692 (you may need to send sms as i cant always answer the phone)
RECIEPTS OF EVERYTHING WILL BE INCLUDED. E.G. ENGINE REBUILD, TUNE, EVERYTHING!
Engine Modifications:
please note: i spray canned nearly everything in the engine bay black lol (wanted stealth look ill put photo up soon)
-MICROTECH LTX12 (LATEST MICROTECH ECU)
- 4X BRAND NEW BOSCH COIPACKS + new relay system
- NEW LEADS & NEW ECU LOOM
- Brand new bosch 023 600hp intank fuel pump
- 550cc primary and 1700cc secondary indy blues injectors
1> Fully rebuilt engine (AROUND 15K OLD) - rebuilt promaz
2>'Tuff stuff' race seals
3> Heavy duty exedy clutch kit
4> BRAND NEW ATR 45 TURBO WITH TR43 FRONT (480HP RATED)
5> custom oil and water lines
6> stainless steel manifold
8" 2.5" INTAKE PIPE AND POD
9> Knight sport fuel cut defender
10> OIL CATCH CAN
11> Front mount intercooler with custom piping
12> Custom 3" dump - front and cat exhuast & 2.5" catback exhaust
13> front mount oil cooler
14> master and slave clutch and brake cylinder and lines (all reciepts included.)
15> starter motor & relay system
16> resprayed lower intake and upper intake manifold
17> all new vacum hoses, clamps, radiator hoses
18> new exhaust and inlet manifold gaskets and seals.
Suspension:
1> Cusco zero, hieght and camber top adjustable coil overs all round
2> new Solid engine mounts
3> s14 / r33 rims sprayed hyper silver (FRONT)
4> 18" X 10" WIDE +13 OFFSET VS - kf Shadow chrome (REARS)
Interior
1> New 5x mechanical Defi style 60mm gauges
Boost (bar version), air fuel ratio, water temp, oil temp & 10,000rpm gauge. - controlld by switch in cabin
2> aftermarket black steering wheel
3> STANDARD GEAR KNOB
4> drift handbrake button
5> Sunvisor DVD player.
6> brand new jvc headunit mp3 etc.
7> 4" speakers front
8> 6" speakers door cards
9> 300w amp
10> 800w sub + ported box.
11> New GT3 Seat cover front and rear
Exterior
1> Resprayed Jet Black
2> standard original s5 bodykit
3> HOUSE OF KOLOR GOLD PEARL
5> spoiler removed and holes filled.
https://www.sau.com.au/forums/topic/285551-240rwkw-rx7-fc-series-5/
shit question but...how many km's you get out of a tank dude?
I got your msg about the swap, and i love RX7s, but it'll be a daily driver, so dont wanna be spending 100 bux a week on fuel
around 350+kms city driving
450+kms highway
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
