From a couple of days on,the stag been feeling a little slow when I accelerate from a complete stop,it feels like it takes a couple of secs.then the revs go up ,the turbo starts to boost an everything goes normal ,until next stop...
Anybody had suffer that before???Any idea or info is welcome...
https://www.sau.com.au/forums/topic/285565-stag-feels-slagish-on-take-off/
ditto.
manual - slipping clutch
auto - bands need adjusting / need a service with new trans fluid
worst case, the torque converter is on its way out.
to add some humour 'slagish', does it spit a lot of slag at other cars :)
i know you mean 'sluggish' ;)
Ok...sorry for my mistake...my car is a bit slug going out the lights...it's auto,and took it for a ride on tiptronic..all felt ok...
BTW where are you in the Se Burbs,Stagea _Neo?Good to see more stags in this side of the planet :)
Do the series 2's have a cable throttle body or drive by wire?
I have a similar issue with the M35, the ecu isnt giving me full throttle at low revs, it opens fully at around 3000 revs. I am planning a manual throttle conversion, I just hope the ecu doesnt get upset.
Scooty - mine is the same ever since the highflow was put back in. Notice it quite a bit - especially when cold! Hit 3,000 and it is a treat
Are you using a boost controller? If not try bypassing the solenoid with the ten minute boost mod (post #40):
http://www.skylinesaustralia.com/forums/Ja....html&st=20
Or a new set of copper plugs
Yep in the se burbs, near the burv.
Apparently there's a silver s1 or s2 near nunna swimming pools, my mates keep thinking its me :). Other than that, black s2 down Highbury rd recently.
Hardly see any stags out this way.
Back on topic....
Another thought is the vacuum modulator on the trans itself, get under and check for
leaking/cracked/loose hoses. (im not sure if modulator is correct term)
Scotty nm35 - nup cable accelerator, no drive by wire.
RBRyan - possibly in snow mode and the light not lit up at the switch on the console?
Or maybe the wires under the console are loose where they connect to the
snow mode plug?
Kidafa - Never known a trans ecu to have limp mode as such.
The main ecu yes. Anyone know how much the main ecu can
change the way the transmission ecu operates?
ie. shift point or engaging full lock up on the torque convertor.
Kiwi - Probably not advisable to increase boost pressure if there is an underlying
issue. Might make things worse.
ie. if it's the torque converter on the way out, it may make it fail sooner.
Trans ECU can go to limp mode if a shift solenoid is playing up, they will lock out of gears etc.
Take it to RVO, get them to plug into it for diagnostics... cheap insurance IMO.
I am in Toorak, work in the city, am out to mt dande a few nights a week, and geelong once/twice a month... See a black stag up mt dande a lot lately.
Do you guys get an indicator on your dash that you are in Snow or Synchro mode?
On the M35 you get the 4 wheel symbol with the drive shafts linking them to show you are in either mode.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
