hey guys I'm just about to head out to my parents place to put a new radiator and a new fan clutch (the davies craig one) in. The fanclutch installation sheet has provided torque settings for the 4 bolts that bolt the clutch on to the water pump/engine/whatever.
But I have no torque wrench ... would it be safe to simply tighten them pretty tight without any accurate torque measurements?? Or should I pay $100+ for a torque wrench which I might never need again ..?
https://www.sau.com.au/forums/topic/285570-how-important-are-torque-settings/
On some things absolutely crucial on others not so much , as a general rule everything should be torqued that has an extremely low or high torque setting and common sense could apply to the rest, try to remember how tight the things are when you take them off when you reasemble is a start it's not a good rule of thumb but it's better then nothing.
I invested in a torque wrench years ago and replaced it when it got a bit old, I now use the old one for a breaker bar, if you aren't in a mechanical trade where you're doing bolt stuff all the time it's your call and your bucks if you get it wrong.
Once you have a torque wrench you'll always need it again. :)
I bought a torque wrench just this morning but its too big to fit between the engine and clutch to reach those 4 bolts ...ah well. It instantly became a father's day present and he's happy with it :)
There's no way a torque wrench will fit in there to do these bolts so I'll just have to try and get it as tight as possible without destroying anything ..
On an unrelated note ..changing the radiator too and I've noticed 90% of that foam that goes around the fan shroud edges is completely gonesky ...spoke to clark rubber and the bloke said they wouldn't have anything to suit, hmm.. any other places that might have it ?? Oh yeah ..old radiator, geezus ..80-90% of the cooling fins are completely blocked off with dirt, no wonder it couldn't cool for shit.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
