  • 1 year later...
Bit late now isn't it  :uh-huh:
Come on give him some credit, its only a post from 18months ago and he has to drum up business someway :headspin:
Why not let us know what you can offer us with goods and services in another post, im sure that there are plenty of pople out there like myself looking for something else for there stereo install and not having much luck finding it :(
  • 5 months later...
