  • Replies 196
Posted Images
Sooo much fun!
Thanks to all for the hard work setting up and running the day..excellent job.
The only problem was it took too long to work out how to drive... with all the excitement/anticipation/adrenaline i completley forgot everything I ever knew (or at least, suspected) about important car controlly facts, like:
- understeer can't be cured with more throttle.
- car won't turn in while accelerating in 1st/2nd.
- foot off gas equals weight transfer onto front equals car go where fronts pointing.
- you can't do tight stuff without a handbrake. (actually I never new this one, but i got it now. My handbrakes a bit tired and rolly, mind)
just gotta work this stuff out the night BEFORE, not the night after.
J.
Ian - Fantastic stuff! Thanks for the great shots of my my Great White Whale (hehe).
Are you going to be doing the Thursday run? Can I get you to bring GD2ILA photos on a USB or SD if you are?
Again - thanks a lot.
Yes on the Thumbdrive, no on this week as i'm heading to Canberra on the Saturday so i'm saving the money/fuel but I should be down next week.
Doof: Hotmail account or different email for the desktop pics?
lol, damn these boats and their horrid ability to tame the high seas! :laugh:
Something I learnt is that I need a dif, and I have to tighten up my handbrake something savage... It didn't do a damn thing!
I also need these things, VLSD is of teh ghey and last time I checked my hand brake shoes they had bugger all meat left (like so little I probably shouldn't have been using it at all on Saturday :D )
Group buy on Cusco 1.5 way and Project Mu drift shoes? ;)
...The only problem was it took too long to work out how to drive... with all the excitement/anticipation/adrenaline i completley forgot everything I ever knew (or at least, suspected) about important car controlly facts, like:
hahah spot on. its hard to think while everything is going on! skidpans really show up understeeritis. You were killing it by afternoon but I saw some hge slides from the clubby on the tight track in the morning.
I actually had my front suspension on the softest setting to let it roll to get the weight transfer since we were at such low speeds. Of course then again my springs are very hard by street standards 8/10.
Like Doof said, big difference between stock suspension and aftermarket coilovers.
I just couldn't give evil weevil the satisfaction of a MXfail winning a Skylines Australia competition :D
Thats why I didnt turn up, give you a chance.
(no, I was working :D )
lol, at the difference in body roll :D
alot of different factors, looks of your photo you are about to straighten up but still got lock, on power, Matt is just gone into a turn with more speed, maybe a bit under brakes with ALOT of weight transfer!
what else have you done with yours doof? looks good!
and matt, hurry up and buy some suspension mods :D
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
