Hey all,
Visiting surfers next week for work. Got a Free Sunday arvo and Monday day.
WTF should I get up to ?
Looking for car stuff mostly, hence on a car forum :).
Not so keen on the tourist stuff muesems, parks, zoo's etc.
I already found the local strip club so sorted there also hehe.
Sort of things like supercar hire, track days that are on even good workshops to check out ?
Don't mind the coast... as long as I'm there in someone else's car hahahahaha. Just head to the beach Monday, it'll be pretty empty...... if it's not raining.
lol a lot of help there !
I don;t have a car at moment but can arrange a hire one easy enough IF i find anything worth doing.
Last time in brissie I was over for Jambo, visited Mecury and a couple random importers.
Surely there is more to do ?
Sunday sess could be ok.
Though at this rate sounds like I'll be scaring the locals in my bathers during the day and then the strippers at night.
I highly recommend the latter, Butters :)
For me usually don't have much time outside of business up there, but definately hit up Broadbeach followed by Surfers (pref with a entourage..). Outisde of that I think theres a kart place at Southport, I been to before - had 125cc motor'd karts - was alright. Can't remember the name of them though :) . All the workshops you'll know already!
THEY sit around doing that all weekend.
Try checking inthemix.com.au to see if any music stuff is on if you are youngish and into nightlife.
Google helps re: track days
http://www.google.com.au/search?hl=en&...=cr%3DcountryAU
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
