Hi everyone,
Had one crap day,all i had to do today was drive the car on the trailer and then sunday drive it to melb for its first tune.
well last weekend finished putting the new engine in my car and started it without and issue, was lumpy and running rich (it has big cams) but it ran and i got it to operational temp then tuned it off cheaked for leaks and ect.
finished up and started it drove it out the shed into another shed and noticed the 4wd light was on so checked the fluid in the boot and it was dry, i filled it up and over filled it oh well ill just bleed it out next weekend (this one).
Arrive today at 8 in the morning was cold nd i was grumpy, jumped in the car to moved into the other shed with the hoist to drain the ova filled transfer case fluid, but the car wouldnt start? i tried everything it sorta stumbled with a fire but no luck, in the end i wiped the pfc tune and went to set up the injectors 800cc sard but i forgot the latancey dose anyone know?
finally pushed it on the hoist and removed the transfer case fluid line in the back of the gearbox, it had presure in there and abit of fluid came out, tuned the car ign to the the on position to prime the pumps to push more fluid out but the pump wont fire up? i have checked everything but cant get it to fire up even when i have the car tuning over it wond push any fluid out.
i will be taking it to the dyno monday and just dumping it there i recon i have had enough off the dam car.
yeh thats what im thinking but stupid me in my wisdom wiped the pfc and forgotthe latancey for the injectors, i got new plugs here but there is no point putting them in untill its at the dyno shop or they will just foul again i recon, i had a go at cleaning the old plugs but didnt change anything.
i used gun gleaner and a paint brush they look ok (paint gun glean)
any one got the latancey for 800cc sards? im lazy and dont want to push it out the shed again.
but the 4wd is what im worried about but might just have to wait till its running
.8 gap and chamion iridium, got new splitfire plugs ones to go in for the dyno will be gaping the new ones to 1 because i have new coils so will see if it blows out the spark then close the gap up if needed
Also, the fluid inside the transfere case and the fluid for the resiviour in the boot are sepperate if i remember
draining the transfere case doesnt mean the level of the resoviour in the boot will go down, the resiviour in the boot is used for the hydrolic accuation of the transfere case.
you can bleed the lines at the pump above the diff if you want the resiviour down.
sounds like you have bigger problems, the car will work in 2wd mode, once you get it going
Edited by V-Spec
bin them they are junk and fit bcpr7es.
did you unplug the attessa bleed jumper under the dash? (little white plug)
and my life gets worse!
Dropped the gtr off monday at the dyno shop and headed back hm with the patrol and trailer 500k trip back home got 460k and blew the engine in the patrol.
done some quick research and found that 3.0 turbo disel partols suk arse and if you have one sell it now! ours had only done 130,000k and we have owned it since new, there is a common problem the pistons melt around the 100,000k mark.
Bugger sorry to hear, yeah unfortunatley thats a common 3.0t patrol issue. One good thing though is that parts are cheaper than say if you blew a tb48 etc...
lol just been looking at the list of engines i have killed
magna (was half dead wheni got it in my deffence)
rx7 ser1 13b
r30 skyline multi engines about 4
honda prelude 89
r33 gtr
2001 patrol 3.0td
im to scared to ride my push bike atm i might blow that up to.
if the rb pops again im going to burn the dam thing.
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
