Just a random out there one.
I got my first yellow sticker today. I was driving very responsibly down the street when I got pulled over by a Highway Patrol. Apparently my Carbon Fibre bonnet is stronger than a regular car bonnet and it is a hazard to pedestrians when I hit them (like I aim for them or something). Apparently a regular bonnet gives a little when a body hits but a Carbon Fibre one won't. ???
Anyway, now I have 10 days to get it sorted and inspected, but I will be away from Monday for 9 days.
hmmm
Blinky
https://www.sau.com.au/forums/topic/285620-my-first-yellow/
If you were to hit a pedestrian at a speed where the bonnet would shatter, the cuts would be the least of his/her worries as they would resemble minced meat from the impact anyway.
Just put your stockie back on and when the lickie is off, go home and put the CF bonnet back on.
Problem solved.
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4795918
Problem solved.
Then get another yellow as soon as he pulls out of the driveway again.
Problem unsolved.
CF is illegal because test dummies get decapitated, or mauled in crash tests
Technically you can get CF passed, but to do so, you need to provide some department with 5 CF bonnets to test out, and then its only passed for that specific vehicle, not every vehicle. The cost to get it legalized would be ugly, if you could actually manufacture CF to guarantee it to fold it set places like regular bonnets do.
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4796071
Just for the record, "WooHoo" was written as sarcasm and not as a proclamation of joy or happiness.
I am now looking at ways of making my stock bonnet look nicer, ie adding vents. I dont think the CF is going back on.
Also, a company named "Blits" does offer a legal fibre glass bonnet.
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4796090
confirm it for WA not just QLD were they are based
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4796100
Problem unsolved.
The cops would give you a lickie for anything they wanted, permits or not.
Problem will always be unsolved until they are held accountable for handing out bullshit yellows.
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4796174
That is an absolute farking joke when 4x4's drive around with great big steel GRATES bolted to the front of them.
Cops dare not anger the 4x4 soccer mums, everyone knows they shouldn't mess with a mob of angry house wives. :)
To the OP, did they yellow you for anything else other than the CF?
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4797464
The sticker was for the CF bonnet, and in the "Other" section they put the BOV. I have an after market BOV on there but it should be legal as it is plumb back.
Any how, the stock bonnet and original BOV are back on now. I had a fiddle with a few other bits under the bonnet that they may have questioned at the inspection, so as it stands now, I am very confident that the sticker will be off by Tuesday arvo. The only nagging things left on the "Maybe Illegal List" is the 3.5 inch turbo back exhaust (hopefullly no emission test required) and the HIDs Ihave lighting the way.
Fingers are crossed.
Also, the CF bonnet is not for sale yet. I might use it as a chop up to modify my stock bonnet. Unsure yet.
Blinky
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4797592
Blinky
let us know if you change your mind about the cf bonnet and decide to sell
cheers
mark
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4798301
Ok Everybody
My final post for this thread.
My 33 went over the pits today and the results are in. The bonnet is good now that it's stock, BOV is good. Everything else is fine. My windows are over tinted so I need to remove the tint to pass and I need to rig my headlights so the low and high beam stay on together if I put on the high beam. HID's were never questioned.
The inspector took it for a drive and even made comment that it was one of the nicest and smoothest skylines he had ever driven.
Then he dropped the bomb. I have to complete an IM240 emissions test.
I will start a new topic post now titled IM240 Emissions Test. I will go through step by step whats happening so everyone else can be prepared if they ever encounter this dreadful test.
Blinky
https://www.sau.com.au/forums/topic/285620-my-first-yellow/#findComment-4801636
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
