I just sold my gt35r. It had an GT turbine housing t3 in and vband out. It was sitting on a 6boost 44mm external gate exhaust manifold.
OK theres the thing. I have a brand new gt42r All vband out with stainless steel housing from TEAL. I also have a 6boost manifold brand new with a 60mm external gate.
Now the Motor is fully built. was Ruining 35psi. I was running a power fc, but I'm planing on selling it for a heltec ps2000 for rb25det.
My question is Whats my best upgrade in the opinion of asu. should i get a gt37r or go back with a gt35r. Can some one give me some specs or set up that would be kick ass. I want about 800-900 hp at the end of the day at about 9000 RMP's. I will do my best to list all mods
1. Fmic
2. turbo you opinion.?
3. hks twin power
4. custom intake 100mm throttle body
5. Sard fuel rail and 800cc injectors
6. Eagle rods and pistons Stock crank redalanced and knife edged.
7. Greedy oil pump and Tomi race main and rod bearings.
8. Built head the works. to much to list
9.6boost t3 44mm eternal gate or 6boost vband 60mm external gate manifold for gt42r.?
10. splitfire coils and hks plugs.
11. All small stuff like External fuel pump upgrade. All lines regulators, boost controller,
I have don my best to give a picture of my car I think i have everything in this motor to take the stock crank to its limits.
I would like to see what the RB25DET can do.
ANY HELP COULD BE THANKFUL THANKS MATES.
Edited by MJTru
Well the GT35 won't make that power and i haven't seen the specs on the GT37 yet... but i assume it wouldn't aswell...
also for that power u'll need new injectors.. they'll be maxed out about 800Hp...
Also it would be easier running water meth injection so you can bring the octane up and keep it cool..
thanks mate. how about the haltec ps2000 ecu. for $2300aud can i get something better.?
I was looking at the AMS GT950R
T3 so i can keep the manifold i have. the turbo is a direct replacement for the gt35r. and i can get it with the same GT T3 vband hot housing, on the cold side i would get the wheel billet so i can get a little more air from it, When you think about it thats about the same as a gt42r i just spools faster much faster. The GT950R is good for 950hp and claims max spool at 4500 rpms. depend on set up.
and the smaller brother the GT850R spools even sooner. check this link for charts on turbo http://forums.evolutionm.net/evo-dyno-tuni...wer-inside.html
Any of you guy's herd of these turbo, has anyone tested them. ?
keep this thread alive mates
A mate of mine is putting a Precision 6765 (AMS obviously trying to lay some claim on it by calling it an AMS GT950R, cute...) on his built RB25 which previously ran mid tens full street trim on a .82a/r GT3582R... I'd imagine it should be running some time in the next month or so. I believe the plan is to get at least 500rwkw out of it, and any more would be a bonus. I can see if I can post results on how it behaves when its done, I wouldn't be surprised if its a little laggier than full spool at 4500rpm but they don't appear to be bad for the power they can make and very very impressive for a T3 foot print turbo.
I am still waiting for more results from them, AWDMotorsport got >800whp out of theirs on E85 and clearly had a broad enough power delivery with it to run an 8 in "street trim" but they were running damn near 50psi.... doubt you're going to be going there. I will try and hunt this thread down if my mates car ends up running any time soon!
There is no other T3 flanged turbo I am aware of which would allow you to make that kind of power, I would be inclined to lean towards a GT4294R with a twin scroll manifold or something along those lines if I were after the power you are talking about personally.
Edited by Lithium
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
