Hi all.
I have searched but cant seem to find a answer.
I am building a RB30/25, using RB25 oilpump, and 1.5mm restrictors to the RB25 head.
On the exhaust side of the RB30 block there is a oil out. I will be using that to feed my GT4084R turbo.
Do i need a oil restrictor before the GT4094R? Or should i just hook it up and leave it using the built in restrictor in the Gt4094R?
Also, there is only one oilreturn in the block, can i hook up, turbo drain, std head drain, and extra head drain to that using a T peice.. (Not T, but with 3 fittings. You get the picture)
Thank you.
Edited by nissan200sx.dk
https://www.sau.com.au/forums/topic/285663-oil-restriction/
Nissan ran 2 restrictors. One at the block and another at the inlet of the turbo.
GCG I believe supply turbo's with an additional restrictor. I reused the factory restrictor at the block on my old GT30 setup and will again be using a restrictor for the new setup.
Its not wise to T in to the turbo's oil drain.
https://www.sau.com.au/forums/topic/285663-oil-restriction/#findComment-4797379
Adriano. Block will be cleaned very good.
Rest:
Garret specify 40 - 45 psi oil pressure on max engine speed, and say"For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section" And I should always check that this is correct.
Info from garrett here: http://www.turbobygarrett.com/turbobygarre...r/faqs.html#t16
So i need to mount oil pressure gauge for that when running my engine?
I would prefer not to weld in the sump. So i will drill and tap 2 x 10mm holes in block. Both used as return for oil from the head. Will use the std hole in block for turbo return.
Thank you.
https://www.sau.com.au/forums/topic/285663-oil-restriction/#findComment-4803668
Huh? No restrictor at all?? I know there is one in the turbo, but I should fit no extra?
This is from Garrett's wesite.
"Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo"
I will be using RB25 oil pump, with hydraulic 24 valve head fitted with 2 x 1.5mm oil restrictors to the head from block. And 1.5mm restrictor for the VCT valve that will have it own hose. (Drilled in the head, and coming from side of block)
I have NO idea how much flow the oil pump makes with this setup. I have oil pressure for engine and can fit oil pressure for turbo also if needed to make sure. I dont want to blow my brand new GT4094R. hehe
https://www.sau.com.au/forums/topic/285663-oil-restriction/#findComment-4803872
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
    • yeah the south island is stunning, the wifes family is from the west coast down there so we were down there for christmas.   a high 10 would be a stretch but hilarious if it happened. fourth gear is its party gear, i don't have traction to throw more at it at lower speeds. I've found passengers don't think its that fast, i think it's because it has a digital dash so they can't see the needle move so they have no sense of speed
    • You have (externally anyway) a lot of patience!  At the very least your patience has rewarded you financially even if you decided you were over it!! I only just read your first experience of seeing the car, that would have been amazing!  Well documented too! It must be exciting knowing there's only 10 months left until you can get it on a boat and on it's way!!!???
