Selling my HP Pavilion DV7 Laptop. Only used it for 3 months whilest working up north. Didnt really use it every day, and when I did it wasn't for very long. Got no use for it now, its been sitting around not being used for a few months now, so I want to get rid of it. It's practically brand new.
Stats:
-Intel Core 2 Duo processor P86
-HP Webcam
-640GB 9320GB x2 - 5400RPM) dual hard drive
-4096MB DDr2 SDRAM (2 Dimm)
-LightScribe super multi 8X DD+RW with double layer support
-Windows vista Home Premium (32-bit) with service pack 1
-HP QuickPlay
-HP Mobile remote control
-HP Integrated DVB-T/Analog TV Tuner & HP Media Remote control
-Fingerprint reader
-17.0" Diagonal WXGA+ High-definition BrightView Widescreen Display
-nVidia Geforce 9600M GT with 512MB DDR2 Dedicated graphics memory
-Intel WiFi link 5100 Network connection & bluetooth
-5-in-1 Digital media reader
-ExpressCard/54 PC card slot
-Expansion Port 3
-High capacity 8-Cell lithium-Ion Battery
Paid$2,300
The carry bag cost me $150
Selling For $2,000 including carry bag.
https://www.sau.com.au/forums/topic/285666-fs-hp-pavilion-dv7-laptop/
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
    • After an excellent condition, working! oem radio for a 97 r33 And the steering wheel shroud/cover as mines a little bit scratched up Am in Melbourne
    • So my exhaust is loud and sounds awesome (good thing) but also is very loud when coming and going, dont want to piss off the neighours etc Are the varex adjustable mufflers any good? I contacted them but they dont make r33 specific exhausts Ive also see the adjustable inlets on this site but apparently they might restrict airflow too much which wouldnt be good for the engine. Would prefer something thats adjustable from in cabin so i can change it on the fly, dont really want to put in one of those permanent exhaust tip things.  Any other recommendations would be appreciated!
    • You don't need to lean as far to pour the oil in, or change the spark plugs either 😛
    • Indeed, it is much easier to get at the filter with the engine on a stand
