Real nice attitude buddy. Real nice
^^ And I care about your opinion because ...?? Clearly the guy is an idiot as R33 and R34 boot lid designs are completely different.
  • Replies 82
Tail light covers sold pending payment.
email [email protected]
r34 gtr boot lid silver colour $120
r34 gtr vspec rear bar, bayside blue $400
r34 gtr front bar silver colour (no lip) $300
r34 gtr front bar lower carbon lip (needs repair) $200
r34 gtt tail light covers $120
r34 gtt Greddy s-type coilovers, 6 months old. $1850
r34 gtt Greddy coilover electronic in-car damper controllers $450 (will do a better price if bought with coilovers)
r34 gtt Cusco 1.5 way type-MZ limited slip differential $1000
r34 gtt denso 670cc injectors + aftermarket rb25-neo fuel rail $800
r34 gtt Bride drivers seat rail for bucket seats (e.g. Zeta III, Guardis III) $200
The bar is costly to freight not because of the weight but the volume measurements (185cm x 85 x 50 for the bar.. not sure about the lip).. freight will be around $120. I'll do the bar + lower lip for $450 + freight to sydney
From now on, anyone who is interested in big parts and is interstate, you will need to organise your own freight... tired of getting quotes and people wasting my time. :)
i have for sale only what's listed.
Payment received. GReddy coilovers now sold.
r34 gtr front bar silver colour (no lip) $350
Injectors sold (Deposit taken)
r34 gtt Bride drivers side rail for bucket seats (e.g. Zeta III, Guardis III) $200
EOI - I may also be selling a set of near new Garrett -5 turbo's... they have done about 10 hours on an engine run in. $2300 with standard wastegate actuators.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
