My 1994 Mx5 Clubman
evil_weevil
 Share
Hi guys n gals!
Thought I'd put a thread up of my nugget here!
Just a bit of a background....I had a 254rwkw R33 gtst for over 3 years, was just getting a bit costly for me to run at the track etc while Ive got a wedding coming up. So after 6 months of looking for a cheaper replacement, I found the mx5 up in QLD.
The car was built and logged as a CAMS 2F race car.
Can be eligable for FOSC, Prod Sports, MX5 challenge, etc
(I'll hopefully be doing MRA and MX5 challenge in 2010)
I havent done too much since buying it, but previous owner bought it stock standard and stripped it and caged it and log booked it!
He raced it for over a year up in QLD, but got into money issues and needed to sell. And I needed to buy :)
So...
Its a 1994 MX5 NA8 Clubman.
Mods when I bought it...
6 point cage
sparco drivers seat with 5 pt harness
daytona passenger seat with sparco 3 pt harness
TEIN Flex coil overs
Whiteline front sway bar
Some a/market caster and camber bushes etc
Brake master cylinder brace
stripped interior
CAMS approved tow hooks and kill switch
Braided brake and clutch lines
Toyo R888 semi's
A shot just after I bought it.
Got it engineered down here in NSW through Greg and Brad @ autosport engineering - big thumbs up there!!!!
Since I have owned it, I have added....
MX5Mania cold air induction - can see it in engine bay shot.
(s13deviats s13 in background!)
Full exhaust system,
4-2-1 extractors, high flow cat and 2.5" cat back exhaust
advanced timing from 10degrees to 14 degress.
Also added RDA slotted rotors with QFM A1RM pads
Just Jap shift light
So far times I have done...
Round 2 SSCC interclub supersprint March 8th - OP GP
1.30.4 - first in class 2B
Round 3 SSCC interclub supersprint May 17th - OP South
55.2 - first in class 2B
Round 4 - SSCC interclub supersprint June 7th - Wakefeild
1.15.1 - first in class 2B
Round 5 - didnt race as was flagging - Wakefield
Round 6 - SSCC interclub supersprint August 2nd - OP GP
1.27.2 - 1st in class - 2B
Round 7 - SSCC interclub sprint 13th september
54.2 - 1st in class
Round 8 - SSCC interclub sprint 18th October
2.00.4 - 1st in class
Car prob makes around 70-80rwkw! It has pretty good corner speed, just lacks straight line speed LOL
Plans for next year are cams and an ECU - can net upto 100rwkw - while its not MASSIVE power, it helps in a lighter car!
Anyhoo, a few pics from some track days,
While its not going to set any world records, its a fkn fun car to drive, and will teach me alot about driving @ the track, and set me up for later races and door to door!
Here is a vid from our SAU NSW OP GP day
Thanks for reading,
I'll update as I go :bunny:
Cheers,
Chris
very nice mate
  • Replies 188
Posted Images
LOL
no chriping cause it was too wet..I had to becareful with the throtle with all that powaaaah!! LOLL
no blower, if anything, AVO turbo kit, is cheaper haha
Nar not a car trailer, I bought one about 12 months ago.
It is another car for a bloke, he has been coming to me for a while now getting bits and pieces done. I have a new engine on the stand to go in it vroom vroom, Then it will be the MX5's turn.
Show us ya knob hehe.
  • 3 weeks later...
yeah Im loving the black wheels!
I just need a black front lip and yay!
so july 11 is EC. first supersprint this year for me....
my goal is to get under 2mins - however I doubt it as I havent been behind the wheel at the track since december :(
  • 3 weeks later...
 Share
    • Update...  After my last update there was two issues I ran into. The first was the driveshaft, mainly that I wanted a 1350 joint on both ends as I am making ~700+whp... Spicer makes a 1350 yoke out of the CD, but looking everywhere all I could find was 1310's for the rear diff face yoke for the R200 (Mine happens to be a z32 swap). Until I found Driftmotion out of CA makes billet R200 flange yokes, I reached out to them to verify if they offered an Old style R200 not the 350z style, and Arron said they had a few in both styles. Anyways Arron over there is awesome, so I gave him my measurements and a week or so later I got my new driveshaft. The fit up is solid, however I did need to remove the cup on the back of my CD as the shaft yoke was too wide to fit in the cup. The driveshaft is sorted and will handle everything I throw at it. I also tig'd up a mild steel trans mount. I used an energy suspension T56 trans mount as they work for the CD, it's universal so cheaper and easier to find. I made a decent mount, I am absolutely not a fabricator but It will work. I intend on replacing It at some point with something I model in CAD and send to send cut send. When I built it I used some trig to get the operating angles right since I did not have a driveshaft at the time. I left myself some gap to shim the trans up with plates to get it dialed in. The only thing that bugs me is I went a touch too narrow on the cross bar, but it supports and functions well.  However my current and persisting issue is with the clutch. The first pass of "Final" install on the trans I reused the pivot ball and fork from the CD as the setup was identical to what I was running on my RB big box. However once it was installed  it was clear I did not get the full travel only half. I thought it could be that I am running the transmission plate or the fact there is really 2 pivot ball sizes 41mm and 54mm. Mazworx was not super helpful and said "the bell housing was dimensionally the same an OEM one", and that I need to "use an RB26 push config" which is technically what I was using. So I ordered the 54mm pivot ball incase that is correct, Tonight I swapped it in and it also does not seem correct. I am going to spend some time researching, because I hope they don't mean I also need to run the stamped steel RB26 fork, and I want to avoid purchasing the $500 tilton kit. Either way this is where I am currently stuck... One other note about the Mazworx housing, the clutch slave provision does not fit either, so I will need to clearance material to make it sit flush with the mounting face. Side note, I am using a RB25 Spec twin disk clutch, It worked great on my previous box, their kit is the same for GTS-T and GTR so I don't think the clutch is the problem.
    • 100%  I actually enjoy driving the Tiguan around, has adaptive dampers, launch control, TRI zone climate control. With the old set of tyres, Continental Sport Contact 5, it kept up to my friend's S13 going through Old Pac. Yeah of course, drove it literally just 2 months ago.
    • If you have an active leak it would be badly contaminated again by now....I'm pretty sure it is just residual. BTW I suggested checking under the oil cap, not radiator cap. Finally, cooling system pressure testers are cheap to buy, that will tell you with a reasonable degree of confidence if there is a leak anywhere in that system.
    • I don't imagine so. It's less about "parts" than it is about process. You just have to screw on adapter ports, because R143a systems have different port valves to R12. Then you need to pump down the system, inert it and extract the old oil and replace with new R134a compatible oil and the refrigerant itself. All done by an AC mechanic (who are the only people licensed to handle refrigerants in Oz). Yes. Absolutely. 60km/day to/from work and whenever else needed. I don't care what anyone else thinks. They're just dirty old Datsuns that were built to be used**. Not f**ken' hero cars to be kept in a shed. **Says he who has one of the nicest, cleanest ones around.
    • you suck Luke.. congrats on 60k
