  • Replies 188
Posted Images
so over the weekend tried to see if I could build a new intake. try and route it down by radiator and put a pod near wheel arch.
got some measurements but decided for now I'll get rid of the AFM and put a straight through pipe in.
seems to have worked a treat.
not with the pipe fitted and reworked the original bracket, the intake seems very flush and doesnt move one bit. Finally!
oh, and the AFM seems quite restrictive..!
now for those smart techy people, is it worth putting it back on the dyno to see if all ok? Im not exopecting any gains I guess just to see if all good.
  • 1 month later...
  • 1 month later...
Finally an update...
MRA Round 2.
qualifying was tough, we had 23 cars on the track. 15 MX5s and 8 Excels.
couldnt get into space and managed a 1.13.2 putting me 11 out of 15 on the Mx5 grid.
race 1 got a great start. made a couple spots up the field however last lap I tried too hard and came off and spun at turn 4, did a 360, car stopped and stalled and wouldnt restart. My first DNF this year.
that put me to starting last on the MX5 grid (we had a shared race with the excels)
made a few moves, got ahead of some others, last lap chasing the bloke from race 1 and I manage a PB with a 1.12.3
not bad for 82rwkw!!
last race was the trophy race. the whole race was an epic battle as you'll see in the vid below.
enbded up 3rd in 2F class again which was great.
my PB lap
race 3 highlights
Next event is FoSC 1st June.
  • 4 weeks later...
not much of an update, havent touched the car since last MRA round.
did Festival of Sporting Cars today at SMP soouth. was in the race class 'historic and invited sports cars'
qualified 5th out of 21 with a 1.05.68 and race 1 ended up 3rd with a 1.05.67!
now the interesting part. I came 3rd but did the 7th fastest lap. So in this meet I started 7th based on lap time. weird. Anyhoo, race 2 came 5th and thats when the rain started to hit.
last race was a handicap race. So if you were slow, you had a better starting place on the track. We all started at same time but everyone was at different starting points. Ended up catching and overtaking quite a number of cars in the rain. Turns out I came 1st! won the last race!
vids to come.
one thing about FoSC which I think is fantastic is the lunch time partners parade.
As my Dad was out there watching and supporting me, I couldnt think of anything better for him than to throw him the keys. He ABSOLUTELY loved it! might see him and his NA6 out at the track soon now, think I got him hooked!!!
on the dummy grid for last race
not the clearest photo
race 1 mazda dominate!
me in 3rd.
http://racing.natsoft.com.au/635483948/object_12206240.91W/View?7
  • 5 weeks later...
hahaha
yeah slight flesh wound. first racing incident in 4 years.
but thats racing mate!
Was still happy with my efforts at the start of the day.
qualified 20th out of 27 in TT and then came 13th race 1.
MX5 qualified 3rd overall out of 8, but came 4th race 1 and then went down hill there. slave cylinder issues causing me to miss gears in TT race 2.
trophy race TT came 3rd in under 2L and then trophy race MX5 at turn 5 copped a wack rear RHS and got spun off.
didnt want to risk it so came in to pits for DNF
  • 4 weeks later...
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
