  • Replies 188
Posted Images
FTW!!!
I just wish I had your front lip!!!
then I'll be set :bunny:
taken the 32 to the track yet Dan?
Nah not yet. I got new 500cc injectors last week to go with my Z32, pump and new turbo so I just need to fit/tune them and then... race seat, track tyres, sway bars then hit the track in october hopefully. It will be interesting to have power but I think braking will be the weak link
  • 1 month later...
So,
got the cars suspension reset by Peter at Road and Race in Rydalmere - feels like a completely different car!
Also fitting an OEM lip and headlight scoop for wank factor haha
bought some gauges too
rice to the max!
Morgan Park in November - cant wait!!!!!!!!!!!!!!!1ty
  • 3 weeks later...
so...
I was hoping the oil press gauge would work straight off the existing wire...but it doesnt
the neg and pos wires were wired up and worked, but the actually pressure one wouldnt and would go straight past 7 on the gauge
doh!
any ideaS?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
