Rebuilding The Rb25det
Good day everyone,
I just recently started buying all the parts i need to rebuilt my RB25DET engine. My CP pistons arrived couple of days ago and I was wondering if i need to buy a set of eagle rods too to achieve a reliable 300 rwkw or can the stock rods handle the pressure? Its a street car but will be going to the tracks ones a month.
Some ppl here told me that the stock rods can handle it with no problems as long as i dont over do it but i wanna know what the ppl here would say about it cause you guys know a lot more about these cars.
Thanks in advance for the help.
Good day everyone,
Standard rods will definitely do the job. Just make sure you get them resized and replace the rod bolts with ARP items.
At the end of the day, it doesn't matter if you get titanium rods or stay with the standard ones. If your tuner mucks up, it's all over anyway. Spend more money tuning the engine than you think necessary. Don't get this mixed up with going to the highest price tuner though.
Depending on where you are, there are plenty of great tuners around.
Status Tuning down south
EFI Performance and Gavin Wood in Brisbane
Could name more but I don't really trust anyone else.
Thanks for the reply. I will order a set of ARP rod bolts this week, to be honest i never thought of buying these :D good thing i asked :D
Wish i could go to those tuners but i'm half way across the world D: but there's a very good tuner here thats gonna tune my car. A lot of ppl here trust him, he has built a lot of high powered cars.
Stock rods are OK.
but...
You could put GTR items in though, 2nd hand they are super cheap and very strong. :D
Plenty of 400rwkw motor's around with stock rods (forged pistsons, arp bolt, better bearings etc etc).
Stocker GTR rods are excellent, some people have pushed higher than 400rwkw without any issue at all as well.
And better rod bolts = great idea, a must have IMO.
I will see if i can get the GTR rods, it will probably be a very difficult find though but i'll ask around. I've ordered a set of ACL main and rod bearings for rb25, they should be arriving this week. Will they fit the GTR rods?
They are all exactly the same. Why go out and buy GTR or Neo rods when you can just use the rods you have in the engine already?
Oblivion makes almost 300rwkw on standard rods in his RB25 with ARP bolts. His limitation is that he has standard injectors but it's still a strong engine and capable of well over that. The weakest link in the RB engine is the factory rod bolts. Replace them and get a good tune and there is no reason why 400rwkw is not out of the question in a reliable engine.
Only 4 things will break these rods at those power levels:
1: Severe detonation
2: Stretching the bolts by over revving
3: Oil starvation causing the bearing to run, then seize.
4: Incorrect resizing or assembly of the rod or rod/piston
Indeed, i'll stick with the original plans and keep the stock rods and get them resized. Ordered the ARP rod bolts this morning, they should be arriving sometime next week. Thanks again for the replies everyone, really appreciate all the help :P
I currently have a RB25DET running all stock internals. Just reconditioned it with new bearings and ARP rods and all. Making 298kw (400hp) no problems (aside from the stupid gearbox :D ) since build and running strong. I would also agree that tunning is vital after build.
I have a R33gtst and the engine was rebuilt all std but with forget acl pistons. I have upgraded alot of things like injectors, ecu, highflow turbo etc.... And the car has a very SAFE tune of 265.5kw because my tuner doesn't know how much the engine will take before it breaks (Because he didn't rebuild the engine). Will just replacing the rod bolts be a good idea and push more power through? Or would it be much better to just enjoy the current power and get a full rebuild later down the track? Can the rod bolts be changed while the engine is still in the car by just dropping the sump?
Edited by shotter
There is no telling when it will go bang. Some people have blown them up at less power output than that, others have them over 350rwkw without issues.
It's not exactly the power that kills them, it's the rpm you take it to. Anything over 7k on the standard rod bolts and you're asking for trouble. I would even be inclined to keep it at 6500rpm to be safe and just enjoy what power you can make up to that point.
No you cannot just drop the sump and change them. Well you can but it will not last very long.
Rods need to be resized which means complete engine strip apart.
Sorry i was meaning just to replace the bolts.
Yea i am reving it no more than 6500rpm.
It's a handfull sometimes so i think i will just enjoy the current power.
Thank You
Yes I know what you meant. The answer is the same
For my engine rebuilt i got ARP head and rod bolts, ACL main and rod bearings, metal gasket, cp pistons. Gonna resize the rods, prep the the block and head just so i can enjoy a reliable 300 rwkw or more depending on the tune. My plan is to do it right the first time. I dont think by only replacing the rod bolts would help you get a reliable 300 rwkw without any of other standard parts letting go somewhere down the track. A lot of rb25det's have met a faith like that on this island.
 Share
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
