Viva Garage...... search them first. some of their kits are shit quility IMO. Theirs a silver S2 stag here in SA with one of their kits on it, the alignment is wrong as on the rear bar. Kit also looks way to massive for the car,could be due to stock wheels with no offset so the guards are empty make it look likea 4 wheeled cheese cutter.
...make it look like a 4 wheeled cheese cutter.
lol.
MASA FTW.
FWIW, If I was going to spend a fortune on the conversion (the best part of 80% the resale value of the car), I really wouldn't bother with anyone else.
Hello
Does you guys know any website where to find r34 conversions for stagea ? I know about masamotorsports but maybe you know any cheaper place ? It´s ok with copies to.
Simon
Custom Carbon Components do a conconversion kit here, but i couldnt immagine the cost to get it
shipped to your location. Their kit is top quality though from others ive seen fitted...
yeah it's just the wheels that make the kit look big and bulky. masa is a nice kit, the viva garage cope of it isn't any 'bigger' than the original, in fact some parts are shorter :D
Hahaha yere just a bit shorter in some parts :thumbsup: .
nothing more embarassing than suffering in length hay....?
Thankfully I dont have these issues with my stag lol
Wait till you guys see stagharts's car when its finished asthetically soonish. MASA kit TE37's lowered fmic leather re trim, list goes on. going to be one of the nicest stags here in sa
I would not go the Masa kit. Too much work. I used the genuine Masa guards only and all genuine factory GTR parts for the rest.
The Custom carbon kit is the way to go. Full kit with lower vspec diffuser to suit the stagea is approx $4600 AU plus headlights.
No need for custom bonnet hinges, bonnet catch etc. Total bolt on. You could strip the car and have this kit on in a day ready for painting
That pricing includes our Australian GST. Since you are are in Sweeden the price will be less as you do not need to pay the 10% GST.
Also better quality and fit than the Masa stuff. I still had to rework the Masa guards to fit
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
