  Curtis.Cow said:
hey,
i was just after some info on getting an maunal conversion done to my automatic r33..
the more info i can get on prices and what i need the better =]
thank you all for your help =]
I think converting to manual is to expensive, i would sell the auto and just buy a manual r33.
  Curtis.Cow said:
whys that? is it seriously that expensive? :\
apparently so, im trying to get my auto R34 GTT converted and its almost 3k for the parts alone =( another 2-3k for the labour. hurtbox for me =(
It's just not worth it on a vehicle where manual versions are so readily available. Save manual conversions for cars where manual transmissions are a rarity or you're really passionate about keeping that particular car.
what im passionate about keeping my auto 33?
i got a price on a conversion kit its only $1750, for my r33 im not sure if that includes labour or what not, im guessing its not including labour but he says that its everything i need to do the conversion.
Make sure it's the R33 gearbox that is included in the kit and make sure it covers electricals too, as you don't want warning lights and fault codes as per the ECU cracking the shits at you. Sounds like a decent price...I always factor in $2500-$3000 for complete conversions.
Basti are you passionate about keeping your car an auto or passionate about that particular car and want to change to manual? I is confused :S
Hey guys,
I just joined the forum so coming in a little late on this convo. I'm looking at buying an r33 gts-t from a mechanic for about 11grand. It already has all the mods I was going to do over time so I'm pretty happy with it. The problem is its an auto and the gearbox didn't seem very happy with the boost. Though that was possibly amplified by me driving it lol. I've had a look around and almost every gts-t for sale has a front mounted intercooler, which in nsw at least is illegal.
Anyways, I want to convert it to a manual if I buy it. Are there any inherent problems with changing from auto to manual? eg: problems with wearing parts or electrics or even as simple as the pedals being in weird places?
Thanks for your help,
Galois
i done a conversion about 3 years ago, cost me 4 grand all up then, for me it was worth it as the car was spotless inside and out. things you need as folloews
tailshaft
clutch
flywheel (machine before use)
gbox
shifter
console and inner and outer boot
brake peddle
clutch peddle with slave and master cylinder and hydraulic line
spigot
manual dash
wiring modded
can still use auto computer (i have only just changed it)
can still use auto diff (will be about 9km fast at 100km)
this conversion only takes a few hours with the right equipment so i wouldn't be paying over $1000 for labor, the car acts and looks like a manual except it has the little power/snow button.
hop this helps
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
