hey,
i was just after some info on getting an maunal conversion done to my automatic r33..
the more info i can get on prices and what i need the better =]
thank you all for your help =]
I think converting to manual is to expensive, i would sell the auto and just buy a manual r33.
whys that? is it seriously that expensive? :\
apparently so, im trying to get my auto R34 GTT converted and its almost 3k for the parts alone =( another 2-3k for the labour. hurtbox for me =(
It's just not worth it on a vehicle where manual versions are so readily available. Save manual conversions for cars where manual transmissions are a rarity or you're really passionate about keeping that particular car.
what im passionate about keeping my auto 33?
i got a price on a conversion kit its only $1750, for my r33 im not sure if that includes labour or what not, im guessing its not including labour but he says that its everything i need to do the conversion.
Make sure it's the R33 gearbox that is included in the kit and make sure it covers electricals too, as you don't want warning lights and fault codes as per the ECU cracking the shits at you. Sounds like a decent price...I always factor in $2500-$3000 for complete conversions.
Basti are you passionate about keeping your car an auto or passionate about that particular car and want to change to manual? I is confused :S
Hey guys,
I just joined the forum so coming in a little late on this convo. I'm looking at buying an r33 gts-t from a mechanic for about 11grand. It already has all the mods I was going to do over time so I'm pretty happy with it. The problem is its an auto and the gearbox didn't seem very happy with the boost. Though that was possibly amplified by me driving it lol. I've had a look around and almost every gts-t for sale has a front mounted intercooler, which in nsw at least is illegal.
Anyways, I want to convert it to a manual if I buy it. Are there any inherent problems with changing from auto to manual? eg: problems with wearing parts or electrics or even as simple as the pedals being in weird places?
Thanks for your help,
Galois
i done a conversion about 3 years ago, cost me 4 grand all up then, for me it was worth it as the car was spotless inside and out. things you need as folloews
tailshaft
clutch
flywheel (machine before use)
gbox
shifter
console and inner and outer boot
brake peddle
clutch peddle with slave and master cylinder and hydraulic line
spigot
manual dash
wiring modded
can still use auto computer (i have only just changed it)
can still use auto diff (will be about 9km fast at 100km)
this conversion only takes a few hours with the right equipment so i wouldn't be paying over $1000 for labor, the car acts and looks like a manual except it has the little power/snow button.
hop this helps
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
