Originally posted by WLD747
What do people reckon if i get a T4 HighFlow for a street use car.  would it be a bit laggy?  I want to run 16psi on stock internals.
My mods are below:
R33 2.5L, Stock Turbo, FMIC, 3'' Exhaust System.
Would it be fun to have as i have a large cooler.
Cheers
AK
It would depend on what specs the turbo is, but yeah, if you pick the right combo, it can be heaps of fun :D
Although, with a larger turbo and higher boost, you'll definitely have to pay some attention to the fuel system, otherwise the motor will go BANG!!!
//RS500.
The previous owner of my car said the turbo on it was a 450hp T04. The guy at Garrett told me it was a T04E when I asked him what it was (I didn't say "Is this a T04?")
Since then though, I've discovered that most other people with T04's have an external wastegate. Mine is internal, so now I'm thinking I just have a T04 compressor cover and who knows what exhaust housing, which looks too small for it.
Small exhaust housing and internal gate aside, it goes really well. Starts spooling at around 2000rpm, and full boost (15psi) at 4500. Which is a little laggy, but not terrible by a long shot. It still feels quite responsive, and I hope to improve it some more with an adjustable exhaust cam gear in the near future.
It's doing well enough now to max out my AFM, which actually surprises me. I'm now thinking about increasing the exhaust housing size to fatten out the power curve a bit (not necessarily increase it).
Yea i've got one...hi flowed T04, stainless steel wheels...I am told that running absurd amounts of boost is no problem with hi-flowed turbos. i've had it up to 15psi at times...now it makes 185rwkw on 10psi which is just nice for my daily driving. For real good results, an aftermarket ecu would help, but i'm only running an S-AFC, and with something like a rising rate fuel regulator, pushing 220rwkw could be done easily i think...just turn up that boost!
I've got stock injectors and the AFM is maxing out before the injectors. The injectors get up to 93% duty though, so they are being upgraded along with the AFM anyway. A rising rate regulator should do the job well enough for a mild power increase.
I found that my PFC indication of 90% injector duty cycle was actually 100%, any addition of fuel made no difference to Air fuel ratio's
hey wld747, my boost starts at about 3500rpm...n yea, higher boost seems to help the turbo do better. the power really comes on after about 5-6psi. I only just found that out. works almost like a vtec
The rising rate fuel regulator will even out the fuel maps so that your air flow meter voltage doesn't max out, allowing you to run more boost. My car experiences boost cut at 12psi now becasue of this, so it's been tuned down to 10psi. the fuel regulator will do away with this boost cut problem (so says gavin wood)
Before I put my FMIC on, I was running 15psi momentarily with no problems, the car made 200rwkw back then...now it makes 200rwkw on 12psi.
basically, just get an S-AFC plus a fuel regulator, and u should be fine. 16psi will be no sweat, if that's what u want.
  • 5 weeks later...
anyone know if most T04 turbos have internal or exteral wastegates?
and what costs have people had when putting a T04 onto their RB25.
I got some questions also need answering so please help.
* I need a new exhaust manifold to put the turbo on! Right?
* Do i need new oil / water lines
* Whats the wastgate part?
thanks in advance
ak
I got a t4 on my RB25... and it's for sale too at the moment :D
Did you ever come on a vic cruise up until approx 4 months ago???
t4 turb's are external wastegated is you have a true t04.
But i have a t4... with a t3 rear on my RB25.
so with the t3 rear you dont need an external wastegate :D
So my setup is like JimX.. t4 core/front housing.
and the t3 style rear end.
Most people think that when you say t3/4 (which ours are) that people mean a t3 CORE machined out to fit t4 wheels in.
You might be able to fit it to the stock manifold.
From what i've seen on a number of cars lately... anything is possible with a bit on enginuity (sp)
As for response same as JimX, it was a little laggy but overall not too bad.
13psi at 4200rpm or so.
and down at BMT we made a lazy 203rwkw on 13psi.
but i reckon the turbo wasnt near it's efficiency range at all as we bumped it to 15psi quickly and gained 30rwkw.
But then the fuel system wasnt too happy with that and needed more than just a fuel pump. So i'd suggest injectors as well as a fuel pump.
little bit more boost, about 17-18psi.
and then it's REALLY get up and move.
I reckon go for one! Is you set it up right as RS500 said then you wont have a problem at all with it.
and they are cheap to rebuild too :P
dont forget mine is for sale :) :headspin:
Nrage33 do you have an internal or external wastegate?
ash
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
