Selling my RB30 + Turbo set up
This was built by myself and dad (mechanic), block work done by Westend performance and tuning by Tom and BD4s
Engine has ran flawlessly for the past 4000km and a lot of good parts have gone into it..
Car ran in on 230rwkw and ran for about 1000km with 270rwkw with the small 8cm rear housing turbo
This will fall into an gtst with no issue.
Off the top of my head parts & work done:
Rb25de head (rare r32 head, no VCT)
Reco rb30 block (bore, hone, acid dip etc etc)
Reco rb30 crank (crack test, linish etc etc)
Cp pistons 9:1
Restrictors in block
Reco head
Gtr valve springs
Cpc custom plenum with billet throttle body (will come with acc cable to work in gtst also master cylinder to provide room)
Gates powergrip timing belt
New waterpump
Recondition oil pump
Crank shaft collar
Tomei cam gears
All new gaskets
Tomei head gasket
New tensioners
New king bearings, all replaced
Powder coated cam shaft covers with welded -10 bungs
Reco power steering pump
Hks fconV pro with map and air temp sensor
Gtr injectors
Price 5.5k
I'm sure there parts i've forgotten to list also
TD06 20g with 8cm read housing
Had this set up previously on my rb20 and made 260rwkw
anyone with it will tell you its one of the best rb20 set ups you can buy.
comes with:
recondition Td06 20g turbo 8cm rear housing
new front comp wheel
Front dump pipe
Oil line
Custom exhaust manifold
braided drain pipe
Tial 38mm Wastegate
Price $1.7k
If you want the turbo set up + motor i can provide a good price
extra parts i can sell to make the install easier are:
Custom power steering reservoir with lines and earls fittings
Custom radiator over flow bottle
Apexi pod filter
UAS catch can with light weight braided hose
rb20 gear box in good condition
Everything is in sydney and i prefer pick up..
Make an offer if you like but nothing stupid.
Thanks
John
Edited by silver gts-t
  • 1 year later...
