hi all,
quick question for those that don't want to read the rest:
does running a 7psi or 10psi actuator make a difference in boost response if i am running a boost tap controller? theoretically the boost controller should keep the wastegate completely shut until a certain level, right?
long version to help those with infinite boost issues in the future:
i have a hybrid boost controller installed on my rb20. ever since i bought my car it has boosted to 14psi even on its lowest setting and finally got around to investigating.
1. took the boost controller out and routed vacuum line straight from compressor housing to STOCK rb20 actuator. took it for a spin and still boosts to 14psi but just more gradually due to lack of boost controller solenoid.
2. took the actuator rod off the wastegate thingy and took it for a spin. gunned it up a hill in 2nd till 6000rpms and it only hit around 9psi at 6krpms after a laggy build-up. i have an aftermarket x-force dump but i am pretty sure the wastegate isn't hitting it. the wastegate swingy thingy on the outside hits the heatshield attachment first before anything else. so my wastegate should be opening all the way if i don't go straight to 14psi, right???
3. so, went back to the vacuum hose from nipple to actuator, pulled it off and chucked a new one on to eliminate the split hose issue. went for a spin and still hitting 14psi.
4. now i'm here. i assume the actuator is f**ked but dont have access to compressed air to check. might get my girlfriend to try and blow 10 psi into it - hahaha. so this comes back to my quick question - i'm chucking an r33 turbo on soon and it has the 7psi actuator. should i run the 7psi or the 10psi r32 one with my boost tap for best responsiveness or it won't matter? could anything else be causing my overboosting problem that I haven't covered, cos the last thing i want is blowing my new turbo if it's something engine related.
thanks folks
https://www.sau.com.au/forums/topic/285852-actuator-question-quick-one/
no it might not be hitting, what turbo is it.
I.E. if you put a T2 turbo with a small wastegate on the rb25 and run it with up the actuator dissconnected it'll produce a large amount of boost before it chokes because the wastegate can't pass enough gas and therefore forces gas through the turbine and boost is produced.
What your problem is is that the wastegate isn't big enough to pass enough gas to drop the boost below 9psi in the top end. this is your lower limit and you can't run less that that. Any actuator you put on the turbo will then increase the figure because you are adding a further restriction on the wastegate.
Go get you wastegate machined and fit a bigger wastegate flap.
Edited by D_Stirls
how far does it move before it hits the heat shield you mentioned ?
moves around 50-60 degrees, i do get your drift though. how far should it be swinging? if it swings as much as it should, could it still be hitting inside? factory heat shield on a stock rb20 turbo.. shouldn't be an issue but i'll check anyway to be sure.
stock rb20 on rb20det
don't think that's the issue.
i'll be swapping over a turbo in a couple of weeks so i'll make sure the r33 turbo doesn't hit before going on. reckon a dremel is powerful enough to scrub a dump pipe down if that's the issue?
oh shit actually it is getting about 90 degrees
starts at around 10 oclock and swings anti-clockwise till about 5-6
need to take geometry again i think
f**kk. so it should be opening all the way.. could it be that i didnt wire it open? thought that exhaust gas would be suffiencient to push it open.
Edited by rawd
what boost do you want to run?
are you sure its a stock actuator? (stock gtr ones are 14psi) might be worth looking into!!!!
also what exhaust do you have excessive back pressure may be the cause. eg (blocked cat)
running a 7psi or 10psi actuator make no difference in boost response. eg will still hit 7psi at same rpm but the 10pis one will keep climbing until 10psi
I want to run 12 psi on the r33 turbo - right now I can't get it under 14psi
Could be a gtr - replaced by the previous owner maybe. Still doesn't explain the disconnected actuator still climbing to 9psi. Think I swung the wastegate thing the wrong way though when i disconnected it so I'm gonna do the test again - plus it's fun giving it with the wastegate roaring.
X-force exhaust with twin pipes instead of cannon.
Thanks for the short answer - I guess I'll run r33 actuator with the boost controller then. Cheers.
im fairly certain gtr's are 14psi but they also run a boost restricter (solenoid on the drivers side)
moving along
is dump and front in one (turbo to car in one)
or is it a 2 peace
i have xforce dumps on my gtr and they over boosted like shit
look them off and relised where the split type dumps join the hole was way smaller than the actuator pipe eg (pipe 1inch hole 0.5 inch)
i opened the join out as far as i could never had another problem!!!!!!!
i have attached a pic showing what i am talking about
hope this helps
Interesting that so many people, myself included, have overboosting troubles with aftermarket dumps. They must be manufactured pretty poorly. Alot of them advertise guaranteed boost gains so I don't doubt that sometimes it's on purpose, but most of the time it'd be poor weld jobs / pipe positioning.
In process of trying to get a refund off my supplier.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
