What: 89 R32 GTR
KMs: 86xxx
Contact: Paul 0411 870 159 or through here.
Dollars: 15k. (Few recent invoices - 6.5k for hp, 2.5k suspension, 3k wheels/tyres, etc - it's all done) Going back to an NA cheapie for mobile business. (May look at trades + cash)
At a glance: Just gave it a full gonig over so it's exactly how I want it, stops - goes - and handles properly. Probably only 2000km on everything. 350awhp (fresh tune on 4WD dyno) Vipec ECU, twin plate clutch (very easy to use), fresh brakes, N1 turbos, Bilsteins/full Whiteline setup, 17x9.5 Origin wheels, etc. Did timing belt/idlers/water pump/100k service while it was all happening. Factory wing + a sub/amp comes with the car.
Condition: She's not about to win any shows, but you can get straight in and go for it. This is for the person who values performance and setup.
I built this as a tough do-it-all street car, but running my own mobile business = time for another boring car. Does daily duties with ease. Had a minor nudge on the left side, wheel alignment was not affected. Pics show the action. Just a bit of lovin on the 1/4's and left edge of rear bar. Been like that for a bit, doesn't bother me, but priced to take this into account. Has since had another wheel alignment to fine tune front end settings. Few little things done recently like tie rod end/rack end/rack boots.
Pre-existing parts are noted, everything else has just been put on within the last couple of thousand kms.
Engine
N1 turbos (came on car)
ATI balancer
Splitfire coils
HKS front mount + piping (came on car)
Pod filters (came on car)
Vipec ECU
New timing belt/water pump etc
Fuel
Bosch 040 intank pump
Turbosmart adj fuel pressure reg
Siemens 610cc injectors
Suspension (Whiteline/Sydneykid setup)
Bilsteins with height adj
King springs
Adj camber/caster bushes
Front/rear swaybars
HICAS lock bar (HICAS removed)
Driveline
17x9.5 Origin DNA01 wheels (rash on left ones)
Twin plate clutch (easy to drive - was already in the car)
Falken FK452 255/40/17 tyres
Brakes
Slotted rotors
Braided lines (ADR approved)
Fresh Motul high temp fluid
RB74 pads
Interior
MOMO steering wheel (came on car)
MOMO gear knob
Blitz dual channel boost controller - 4 maps, lots of adjustment, works well. (came on car)
Blitz boost guage
Alarm/immobiliser that winds the windows up for you
Turbo timer
Forgot to mention...
Exhaust
Trust split front pipe
Highflow metal cat
Exhaust (Trust from memory)
If doing a trade + cash would want at least 10k cash, just getting an NA cheapie.
would you consider a r33 NA (few mods) plus about 6K cash?
I would consider an NA 33, but I plan on spending 5k or less on a work car, hence the requirement of 10k cash if doing a swap. I'd prefer a straight out sale, but swap + cash can be very convenient for both parties.
Car also has an alloy radiator + silicone hoses
How much damage is done to the panels?
Can you get a quote on fixing the damage?
Damage is shown in the pics and described in the first post, it didn't even change the wheel alignment so it was pretty minor. - Going in for a quote at a proper panel shop on Friday, I'll let you know.
PM sent to johnbarry.
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
