yep so after havn my skyline for 6 months i jus got my first yellow on sat night.
my mum was driving it (skipperin myself and a few mates to subi), took off from the lights, very slowly and then cops do a u turn and pull us over..
so aparantly my headlight was out - tru, and just a globed
they used a notepad to check the height of my ride (1- mum parked up on the curb so it was angled 2- when i asked if they had a tape measure they responded with, nope dont need 1)
i checked the heights when i got home, my sides are 120mm, front 130, rear 130, so i believe im fine there
they said my front struts have been cut for the radiator... even tho its all bolted into stock mounts (sais my mechanic mate)
and BOV needs to be plumbed - fair enough
also they have asked for a DB test.. all i have is a catback, like the very back part of the exhaust, the rest is stock.. its not even looud and they wouldnt of heard it anyway as mum was driving like a nanna.
thoughts?
https://www.sau.com.au/forums/topic/285904-lol-another-first-yellow-thread/
Your lights need to work
You cant have an atmo bov.
No idea what your on about with the struts.
Even if your car is legal height the bov/light is enough to get yellowed.
If your worried about the volume of the exhaust borrow a dB reader and check.
ah yer, i know lights needa be working - duh lol, and i know about the atmo bov
ive got new globe and getting bov plumbed properly.
prety much jus askn if there is anything else i should get checked before going over pits?
This is starting to get a bit common, never seen so many ' i got a sticker' posts in such a short time. for height , you have to get under your car and measure how far your exhaust is from the ground, gunna have to ba around 120mm minimum to pass
^, ride height is from the lowest part of your car, which could be your exhaust or your diff etc etc.
and do you mean the metal struts that go down infront of your rad support bar?
most of the time, if theyve decided theyre going to give you a sticker, your going to get it. if you argue about something, theyll just find another reason why its unroadworthy..
I must admit those cops on saturday night were so rude.....
And one of the coppers was saying that the BOV is illegal and i was like "umm no its not, that is a factory item" (he didnt know it was atmo).
Funny thing was, his mum was driving and we were like WTF....and these cops legitimately had NO mechanical knowledge.....
The Cops take anyone these days, they have really lowered the bar.
lol main thing i hate is that they didnt even have a f**king tape measure.. and they said "we dont need 1, thats what this notepad is for"
lol it was a fkn passport.. not a fkn tapemeasure. AND we were half on the curb, and they knew it
Agreed
The more reason for me to take the Camry out if I need to drive anywhere after dark on a weekend.
& to the OP good luck with getting your sticker removed.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
