yep so after havn my skyline for 6 months i jus got my first yellow on sat night.
my mum was driving it (skipperin myself and a few mates to subi), took off from the lights, very slowly and then cops do a u turn and pull us over..
so aparantly my headlight was out - tru, and just a globed
they used a notepad to check the height of my ride (1- mum parked up on the curb so it was angled 2- when i asked if they had a tape measure they responded with, nope dont need 1)
i checked the heights when i got home, my sides are 120mm, front 130, rear 130, so i believe im fine there
they said my front struts have been cut for the radiator... even tho its all bolted into stock mounts (sais my mechanic mate)
and BOV needs to be plumbed - fair enough
also they have asked for a DB test.. all i have is a catback, like the very back part of the exhaust, the rest is stock.. its not even looud and they wouldnt of heard it anyway as mum was driving like a nanna.
thoughts?
https://www.sau.com.au/forums/topic/285904-lol-another-first-yellow-thread/
Your lights need to work
You cant have an atmo bov.
No idea what your on about with the struts.
Even if your car is legal height the bov/light is enough to get yellowed.
If your worried about the volume of the exhaust borrow a dB reader and check.
ah yer, i know lights needa be working - duh lol, and i know about the atmo bov
ive got new globe and getting bov plumbed properly.
prety much jus askn if there is anything else i should get checked before going over pits?
This is starting to get a bit common, never seen so many ' i got a sticker' posts in such a short time. for height , you have to get under your car and measure how far your exhaust is from the ground, gunna have to ba around 120mm minimum to pass
^, ride height is from the lowest part of your car, which could be your exhaust or your diff etc etc.
and do you mean the metal struts that go down infront of your rad support bar?
most of the time, if theyve decided theyre going to give you a sticker, your going to get it. if you argue about something, theyll just find another reason why its unroadworthy..
I must admit those cops on saturday night were so rude.....
And one of the coppers was saying that the BOV is illegal and i was like "umm no its not, that is a factory item" (he didnt know it was atmo).
Funny thing was, his mum was driving and we were like WTF....and these cops legitimately had NO mechanical knowledge.....
The Cops take anyone these days, they have really lowered the bar.
lol main thing i hate is that they didnt even have a f**king tape measure.. and they said "we dont need 1, thats what this notepad is for"
lol it was a fkn passport.. not a fkn tapemeasure. AND we were half on the curb, and they knew it
Agreed
The more reason for me to take the Camry out if I need to drive anywhere after dark on a weekend.
& to the OP good luck with getting your sticker removed.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 馃檪
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
    • Best kept secret for seized bolts is crayons... Heat the sucker up with a torch, and push/melt crayon into it. Works a wonder. See if I can go 2 from 2 for you on how to get your bolts out...
