I posted this in someone elses thread but doesn't look like it's been used for a while, that and I couldn't find anything else to help me with... so...
Having issues at the moment in my 32 GTR. Every now and then when it's cold it'll idle rough and accelerate rough aswel. It'll hunt at idle aswel and have to poke rev's at it to stop it from stalling.
I am taking out the spark plugs to have a look once the car cools down a little. I also had it running and pulled each coilpack off sparkplug as it was idling just to make sure I havn't for some stupid reason dropped a cylinder, and the result was the same for all.
Other than what I am going to do in a little, anyone else have any other suggestions?
-Chris
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/
^^ What Mike said.
+ remove and inspect/clean the AAC Valve. Use carby cleaner only. There is an adjustment screw but no need to touch if it was idling fine before.
+ Double check all vacumm lines are loose/worn/split or have come off.... These are reaching 15+ years now so not surprising easy/chaep parts may need replaicng.
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4799326
Thanks for all the input fellas, appreciate it.
Am about to go out and check the plugs, coil packs, harness is OK checked that before when I removed the valley cover, will have to check CA sensor aswel. Was idling fine before this.
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4799426
Just checked spark plugs, the tops of them are corroded as all hell, going to replace them tomorrow. However, just had a mate come round for a 2nd opinion, took it for a drive and we noticed noise coming from the dump/cat area, sounds like I've blown a gasket somewhere, reckon this could be causing rough idle and rough acceleration?
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4799888
Okie dokie. Plugs swapped out. Still has slight rough acceleration and idle and noise still coming from under floor passenger side so seems most likely gasket. Worth replacing it myself or taking it to a zorst center? can't actually see/hear exactly where it's coming from myself.
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4802277
this cars had a new CAS put in so it shouldnt be the CAS
AAC is clean as a whistle cause i cleaned it myself and put a new gasket on it.
Intake gaskets were checked a while ago and all ok, no leaks.
Coil packs are 20 years old so might be time to swap, plus the plugs are approaching a year old.
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4805552
ooohs, that could be fun heeh. Might get someone to do that one for me. But yeah, I replaced the spark plugs and idling better at the moment, not hunting as much. But still definitely sounds like a leak of some sort from under the passenger floor well. Going to take it to a zorst center on the weekend and have it looked at because I can't see where it's coming from if anywhere at all. But also reason I believe it's exhaust related is that it has a weird wrx-like burble while feathering the throttle during downshifts and the like, hard to explain.
Meanwhile, hope you havn't had any further issues with yours :)
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4805632
yeah it sounds like the exact problem i had with the leak. Pop your head under there and you can smell and hear it coming outta the front of the cat. Chris, i forgot to have a look at the painted bay on the antilag cruise, doh! Got any pics up yet? i noticed i lost quite a bit of top end with the leak too
Nah nothing to report from my side of the fence :)
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4806205
Lost top end in my GTR with the leak? Yeah, I seem to have lost a bit of top , I though I'd accidentally set my boost controller down to about 12psi hehe. Looks like I'm going to be getting a gasket replaced then ....
I havn't had a chance to get the bolts for the timing belt cover so I havn't put it back on yet heh.
Glad to hear your's is all good, love that machine... aaaah GTR's ... nothing but the best will do :)
https://www.sau.com.au/forums/topic/285913-rb26dett-issues/#findComment-4806226
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
