Ok this is a '94 GTS25-T Type M, and I'm wondering if it has a body kit - it looks pretty stock except for the f-bar and the rear-wing...but then again it's a Type M so they might be stock too...
Anyone care to enlighten me??
Oh, and yes this is my car :-)
But it's still in Japan :-(
http://www.geocities.com/necroboy2
*edited by Squizz to show proper link... Hope you don't mind :D*
*Opps, yeah thanks - meant to change it to point to index.html after I wrote the page but got caught up in work! ;)*
https://www.sau.com.au/forums/topic/28592-does-this-gts-t-have-a-body-kit/
Yup as above it has a aftermarket front bar, skirts and rear wing. All its missing is a nice 400R rear bar (about $600ish fitted) and that would be damn nice.
Heres some before/after pics of my r33 with similar side skirts (they are 400R), im leaving the front bar standard (gonna customise it) but have a GTR Copy wing waiting to go on.
http://skylines.pnc.com.au/pics/ben/bodykit/
Mmm..nice :D
I just added 2 better pics of the rear wing....I'm still not sure about it as it's quite big so the 400R might be an option, but then again the existing one is growing on me...aw heck I love the car even with it's oversized wing and little dents :cool:
http://www.geocities.com/necroboy2/
Youve got a nice car Benm. Do you live around the Glenmore Park area??
I saw you once, you were going into Nepean Square but you parked in Penrith Pools. Do you have front seat covers with the skyline 'S' ??
I was going to put a piece of paper underneith your windscreen wiper but I saw you put the alarm on before you went into the shops so I left it.
But I remembered you plates, ( couldnt really forget ) then I saw on the aus skyline pictures website your car.
Yup everything you said is correct. I need wheels badly eh....
I park their coz their is no risk of people bashing my doors, its out in the open and their is always a constant stream of cars going past to deter any theives.
Gimme a hola next time you see me/it...
benm.... car looks very nice indeed!! I've just got a fibreglass 400R front and rear but had to settle for GTR type side skirts (4 door)
The rear isn't bad though the way it's set up for attachment is not well designed and is going to be lots of extra work. The front is really ratsh*t...pretty poor finish and nil attention to detail , whereever i've drilled a hole or made a cut i've struck dryglassfibre the thing wasn't even wetted out properly.
Are the origional Jap versions of these kits plastic or fibreglass??
The Nismo ones would definitely not be fibreglass I'd say, but I've never seen a genuine one.
My 400R bar is falling apart too (my cousin was "looking after" my car while I was living in the US). I am beginning to really dislike fibreglass kits.
Does yours actually fit properly? I'm almost certain mine is for a GTR, which has the flared guards of course, so doesn't fit at all on the back. I might have to modify it a bit.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
