Ask(pic): How To Pull Pulley Off The Crankshaft? Bolt Already Taken Off.
hi guys, i'm starting fix the whole RB25det neo engines.
do u know how to pull pulley from crankshaft? i alredy unbolt the big 24mm bolts. then i use wd-40, soak in hot water, and try to pry it off with pry bar. but still cant take it off.
what should i do? sorry for the noob question.
thanks
Mike is right! you need a harmonic balancer puller to get it off.
prying is a very bad idea and I hope you didn't try too hard. basically the balancer is a very tight fit on the crank and if you pry from one side it the balancer does not come off straight which makes it even tighter. if it looks uneven on the crank you are best to tap in back on with a rubber mallet.
see the 2 threaded holes on the front? you need to get 2 long bolts with that thread, a harmonic balancer puller and put the crank bolt back it (not tight but the head of the bolt needs to be inside the balancer again).
slowly turn the bolt on the puller and it will slide off. be very careful to screw the small bolts right in because the thread is pretty small for the force those bolts will have.
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
