the other day my speedo just died in the arse, i take off and it stays at 0 then when i apparently am doing 60 it just zooks up to 60 then moves up to 120 and just stays there, is there any ideas on what i can do to fix this problem :P
cheers
https://www.sau.com.au/forums/topic/285978-speedo/
Probably a problem with the speedo sender unit, but first of all I'd remove the instrument cluster, make sure all the contacts on the back are clean, before trying to source a new sender.
There are a number of threads on this subject already.
http://www.skylinesaustralia.com/forums/Sp...l&hl=speedo
https://www.sau.com.au/forums/topic/285978-speedo/#findComment-4800583
  • 8 months later...
no mate, never solved the problem, after having this problem i had a few others so i havent driven my car in about 3months while its being fixed, the thing i narrowed it down to was the speedo sensor in the gearbox, try replacing it
https://www.sau.com.au/forums/topic/285978-speedo/#findComment-5258254
