Clearing out the shed, and have a few bits and pieces that I need to get rid of
Set of Apex'i shocks, with 1 1/2 inch lowered and nice and firm Apex'i springs. Shocks are damper adjustable, and in really good condition - only selling due to having fitted a set of Coilovers - $550 - offers considered
Trust/Greddy dual pillar mount gauge holder, used for about a month, not a cheap copy, but a proper Trust one, with box in as new condition - $130 *SOLD*
Stock R32 turbo, in good condition, never boosted above stock and very minimal play in bearing etc, with water banjo fittings and stock dump pipe - $250 offers considered
Set of stock R32 rims, with a few scrapes on them and newish fronts and 60% rear tyres - $400
Stock fuel pump and holder (complete) with stock pump that was working 100% when removed - $150
Speco oil temp gauge - mechanical guage with fitting for sump plug, used - $40
2 x 18" Michelin slicks from GTP car (look like about 265x35) used but still good for a bit of fun $50 (Adelaide only)
2x 17" BF Goodrich slicks, of GTP car, 235x45, used bit still ok for a bit of thrash $50 (Adelaide only)
Used R32 GTST front brake rotors, need machining but otherwise ok - $70 *SOLD*
New set of Bendix Ultimate front brake pads, suit R32GTST (not sure but also might fit R33 and S14) $50 *SOLD*
Two fog lights out of R32 GTST Type M in good condition, working with globes - $70
thats about all I can think of for now, will post others stuff once I think of it
post email adress if you want pics of any of the items
Thanks, Chris
https://www.sau.com.au/forums/topic/28598-r32-bits-and-pieces/
Brody - pads are brand new, sealed in plastic. The rotors are in pretty good condition, need a machine though as they have a bit of a lip on the outer edge. I was gonna do that but got slotted rotors and racebrakes pads instead, hence why I have a set of new Bendix pads for sale
Enrico - Will take some pics on the weekend and email them to you, they are in ok condition, I was going to use them but never got around to it
All PM's replied to
I am off on holidays as of monday, but still will be able to check PM's etc, but I apologise if it takes a little longer than usual
It will give me plenty of time to get frieght organized for those of you who have bought some of my parts
Regards, Chris
  • 3 weeks later...
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
